Question about Kitchen Ranges
Thermodor range pg486gdbs
Oven wont shut off
Before you go any further repairs in the oven, simply check that a mechanism for inclusion is not worn and skips when it should be off. Or look at the link Black and Decker Toast Oven Door Spring Mechanism Replacement
Posted on Mar 27, 2014
OUr heating element died 00486945 for our 36 inch Thermodore oven range. Can you help us locate some type of replacement part
Just remove your heating element and take it with you to an applicance store. They will be able to order you a new one. Make sure you cut the power at the breaker before you remove it though.
Feb 01, 2016 | Ovens
Why wont my oven turn off
The thermostat turns on the ignitor. Replace the thermostat
Oct 10, 2014 | Amana AGR5835QD Gas Kitchen Range
The microwave unit in my Thermodore CMT231 has abruptly stopped working. I suspect a fuse may have blown. Is this self-serviceable? I am pretty much a novice.
When you say it stopped working , you mean no lights or display etc. Then that can be a fuse but fuses blow for a reason. Find the reason if the fuse blew.
Oct 14, 2013 | LG LMV1650ST Microwave Oven
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
Fridgidaire elctric oven with the touch control pad
MOST OVENS TODAY HAVE THE CLOCK/CONTROL AS ONE UNIT THAT HAS THE RELAYS THAT TURN ON THE BAKE/BROIL CIRCUITS. SOMETIMES THE RELAYS FUSE THE INTERNAL CONTACTS KEEPING THE CIRCUIT RUNNING AFTER THE MICROCOMPUTER SHUTS DOWN THE CIRCUIT.
THE OVEN CONTROL WOULD NEED TO BE REPLACED.
IT IS ALSO KNOWN AS THE CLOCK.
OCCASIONALLY, THE MANUFACTURER WILL HAVE A SEPARATE RELAY BOARD AND CONTROL BOARD. FIND OUT WHICH CONFIGURATION YOUR RANGE IS AND REPLACE THE PART THAT CONTAINS THE RELAYS.
Dec 20, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Oven Heat
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Aug 28, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
