Question about Ariston Technologies Dishwashers
Ariston L640a, the appliance stops while 2nd and 4th M lights from left flashing rapidly. Thanks
4 Suggested Answers
  • 105 Answers
SOURCE: Dishes not clean after cycle!
Is the water coming into the dishwasher and is the wash motor working or is the sump clogged up so the water cannot get thru.Depending on the purchase date of the dishwasher, if it is a under a year old call who ever you bought it from as it usually comes with a 1 year manufactures warranty.
Posted on Feb 06, 2010
SOURCE: I have an Ariston LL65 and the eco and rapid light are flashing
I have the same issue, so Dish-washer Ariston LL65 with Eco and Rapid light flashing. Can you help me to undestand the issue and solve it ? thank you, Regards.
Posted on Dec 25, 2010
  • 27 Answers
SOURCE: The 4th green light on
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Posted on Mar 02, 2011
I have an ariston ll64 and it is stopping a the last cycle button which is the picture of wine glasses. It then flashes with a green light.any ideas?
Error messages:
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "E" flashing rapidly.
24432725-0h3kxpflbez5mdeb5anq3st4-3-0.jpgFlashing Led diode below button with the image of wine glasses means faulty thermistor NTC. So, could be faulty: thermistor NTC (defective or not positioned), wiring, control board.
Dado
May 16, 2014 | Ariston Technologies LL64WNA Built-in...
L 63 B NA Ariston
one or two wash cycle indicator lights "G" flashing rapidly.
24238319-0h3kxpflbez5mdeb5anq3st4-3-0.jpg In this case could be:
  • Drain motor disabled
  • Filters clogged
  • Drain hose blocked
Dado
Apr 24, 2014 | Ariston Technologies Dishwashers
Ariston LI640A 2nd and 4th light flashing
Usually this is a sign that you should call the repairman. However, I had a flashing light once because I made the mistake of trying to use my Ariston without turning on the water to it. I unplugged it from the power and let it sit for about ten seconds. When I plugged it back in, the flashing light was gone. I am not sure if this will help you or not but it is certainly worth the try.
Nov 15, 2013 | Ariston Technologies LI640S Dishwasher
LL64 Dishwasher 3rd and 4th lights flashing. What does this mean? DC
Please check if the pressure pump is clogged and the sparaying arms are rotating well. It is possible that the program seems to shut down due to an error. So start by clearing the inlet valve, check the flow to the pump and the spraying arms.
Please check this link for tips to investigate:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Nov 14, 2011 | Ariston Technologies LL64WNA Built-in...
Hi, our ariston dishwasher has stopped before the cycle finished and the water has not drained out. There are 2 flashing lights - the brush emblem and the spray ' on a tilt' emblem (the 2 on the...
Error messages.
The dishwasher is equipped with a
These anomalies are signalled by
the rapid flashing of one of the
wash cycle indicator lights M.
If the indicator light for the soak
cycle flashes (see wash cycle table),
cancel the wash cycle by following
the instructions indicated in the
"Modifying a wash cycle in
progress" paragraph on page 4.
Now check whether there is any
water in the mains supply and that
the tap is turned on; if the error
message persists, then call for
technical assistance, indicating
which message appeared.
If the indicator light for any wash
cycle apart from the soak cycle
flashes rapidly, turn the appliance
off and call for technical
assistance, indicating which
message appeared.
Troubleshooting
You have checked
everything, but the
dishwasher still doesn't
work and the problem
persists?
Call an authorised service centre
near you and remember to mention:
? the type of malfunction
? the model mark (Mod?.) and the
serial number (S/N?.) indicated on
the rating plate located on the inner
door, to one side.
Jan 14, 2018 | Hotpoint-Ariston LI 640 24 in Builtin...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
KEY: 0 = LED off
1 = LED flashing
protection system
blockage
Mar 02, 2011 | Dishwashers
Feb 06, 2010 | Dishwashers
Sep 01, 2009 | Ariston Technologies LL65 Built-in...
Ariston a1636 washing machine
I have the same problem, did this get solved for you?
Jan 08, 2008 | Ariston Technologies AW149NA Washer
Dishwashers Logo
24 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
