Question about Vehicle Parts & Accessories
Power window MY cars left side power window not functioning motr faild is it possible to replace as manual type
    Genius:
  • 1,114 Answers
These days power windows are so common on vehicles, there are no manual assemblies for replacement. What vehicle, what year, model do you have??? In the long run, it will most likely be more economical and more straight forward to replace the motor. After market motors are not terribly expensive. Are you sure it's the motor that does'nt work???
Posted on Mar 30, 2014
Replaced battery, now auto windows wont come up auto automatically
If on a GM car the battery has been disconnect the windows may need to be reprogrammed
The following steps explain how to program the side door window regulator motors:
  1. Press and hold the power window switch until the window is fully DOWN. Continue holding the power window switch for approximately 3 seconds.
  2. Press and hold the power window switch until the window is fully UP. Continue holding the power window switch for approximately 3 seconds.
  3. The power window regulator motor is now programmed for the express function.
  4. Repeat this process for all of the power windows.
Dec 01, 2015 | Cars & Trucks
2004 Audi Allroad Power window problem
Possibly a faulty driver door switch. There is a function tied to switch allowing driver to open or close all windows through door switch.
Dec 27, 2012 | 2004 Audi allroad
When I unlock my 2002 vw golf all the electric windows open together ?
.Just to be sure, do you know that when you insert your key into either the driver or passenger (front) doors, and turn the key over to the far LEFT (in the process of unlocking the door), and hold the key in that position for more than a second or so, your windows will all roll down?? This is supposed to happen - it is a benefit of owning a VW! It is all described in the owner's manual.
Now the other side of this function, is that if when you get out of the car, and any of the windows are left open (including the sunroof if you have one), inserting your key and turning it over to the far RIGHT (in the process of locking the car), and once holding it there for more for a second or so, will then close all the windows for you. This opening and closing process will only continue for as long you hold the key turned over in the extreme position in either direction. Once you return the key to the center position, the opening and closing will stop. So you just hold it there until the windows are all closed. This option is not available via your keyless remote though - only via the key in the door locks.
It's something I love about the VW design - you can choose to let fresh air into the car before getting in without having to insert your key into the ignition and on the other side, if a window (or the sunroof) is accidentally left open when you've exited the car, you now have the option to close them all without once again inserting your key into ignition and turning it over.
Feb 18, 2012 | 2002 Volkswagen Golf
Driver side power window doesnt work
Its possible, check underhood fuse box, the position 6, 60AMP for Power Windows
Other details can find in the Ford-Explorer-Owners-Manual (page 187 and next)
If the fuse is OK, take off the trim panel to check the windows motor, windows switch and wires.
Hope helps (remember rated this).
Jul 23, 2010 | 2003 Ford Explorer
Power windows not working
If the power window switches on both sides of the car went out at the same time, I would say that either your fuse or relay for them needs to be replaced. The relay for the power windows is located to the left of and below the steering column either in the door or under the dash, I can't quite tell from the picture in the repair manual. You can download the repair manual here. Right click the link under the heading '1988 BGB' and select 'save as'. Once you open the pdf file, navigate to page 804 to see the picture that I am refering to. If you are handy with electrical DIY projects then see also pages 858-860 to test the switches and relays for proper functioning.
Hope this helps!
Jun 25, 2010 | 1988 Toyota MR2
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
Please give motr of the devices fixed on same heat sink. Search for SMPS IC like FPS or similar, search their application notes and the datasheet of the nMOS. then you can get idea. without those data Solution is impossible.
Jan 27, 2010 | HP and Compaq Pavilion Replacement 200w...
Front power window button will not control rear right side window. Rear right door window control only lowers window no up function?
Most likely you have left the windows on that side of the car open a bitand water has cased some corrsion on the connections. You need to replace the switch if removing and cleaning connection does not work.
Nov 19, 2009 | 2000 Acura TL
'88 toyota camry rear window stuck in down position
To get to the Window:
Remove Door Inside Handle:
remove screw, slide the handle forward.
Disconnect the control link and remove the handle.
Remove Door Trim with Inner WeatherStrip:
Remove the two screws from the armrest.
Insert a screwdriver between the trim retainers and the door panel to pry it loose.  Eight hidden fasteners. 1 top left side of door.
1 right side about same height as top of armrest. 1 (each side) about same height as bottom of armrest. 1 on each corner bottom. 1 bottom in middle.  1 on left side between bottom corner and the previous at about lower armrest height...
Remove Service Hole cover.
Remove Door Glass Run.
Remove Division Bar (upper window section divider):
Remove the two screws under the weatherstrip
Remove the bolt.
Pull out the division bar.
Remove the Window Glass:
Place the glass in the door cavity.
Remove the two glass channel mounting bolts.
Remove the window glass by pulling it upwards.
You now have access to the Power Window Regulator; possible replacement of motor etc.
What type of 'things' have you tried for fixing the window and restoring operation?
Jan 22, 2009 | 1988 Toyota Camry
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
