Question about Samsung Galaxy GT-S5570
Usb does not contact computer - Samsung Galaxy GT-S5570
    Problem Solver:
  • 16 Answers
Check USB Cable,try to use other USB cable or try to plus it into another USB port....
Posted on Mar 27, 2014
How to Transfer Contacts from iPhone to Computer Using iPhone Contact to Computer Transfer?
There is a method for you to transfer conatcs from iPhone to computer directly.
You can choose a reliable iOS assistant tool like MobiKin Asssistant for iOS, it can help you transfer files between iOS and computer.
Learn the details: Transfer Contacts from iPhone to PC
Oct 18, 2016 | Cell Phones
How do I backup contacts?
You are using Android phone, here is a solution for Android phone user to back up contacts on computer.
Transfer Contacts from Android Phone to Computer PC
Just simple steps, you can finish the the work quickly.
May 02, 2016 | Motorola Mobility BT50 Cellphone Battery
Olympus vg 170
To make it possible, to point out where the problem is, you could try some rings.
Try to charge the camera with an external power supply. If you have it, the F-2AC from Olympus.
If that also does not charge, you could try to replace the USB cable.
But if the camera starts charging, you have to look for the USB connector in the computer. Be aware, in some computers the power, delivered from a USB connector, should be capable of giving 5 volt and 500 mA. Sometimes internally the computer is not correct wired, and won't give the 5 volt at all. Special when you hav build the computer yourself, you can check inside the computer. BUT ONLY when is sure the camera can charge via an external USB charger.
Then you could check if nothing is wrong in the camera. All contacts, on battery and in the camera, should be clean and shiny. You could clean contacts with a dry cloth. Never use sharp tools.
Also check the USB connector on the camera, if no debris is in the connector, or no contact is bent or has corrosion on it.
Success
Mar 04, 2014 | Cameras
Usb device not recognised lexmark s405, tried all advice listed in google pages except petrol & lighter.
Have you tried using another USB cable? You can also try plugging the printer in to a different USB port in your computer.
Also, try to plug in the printer to a different computer, if it works then there's a problem with the USB port of your computer. If it still doesn't recognize the printer, it could be the USB cable that's causing the problem or the USB port of your printer. If that's the case and your printer is still under warranty, contact our technical support team to have the printer replaced. You can find the contact number at our site: www.lexmark.com.
Jul 05, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Unable to turn on from power button
This sounds like a USB problem. If there is a short or damage within the port the computor will detect it and prevent it from starting. Usually it's a USB port you always use. This may help, Plug in the mains charger and remove all USB devices. This will confirm weather its the computer or a USB cable/device. If the computer still doesn't start, get a bright light and a magnifying glass and look inside all the USB ports on the computer. In the middle of the port there is a flat plastic piece with 4 metal contacts attached to it. Check to see if they are bent, twisted or flattened in any way and with a pin or other suitable pointy device, attempt to straighten any damaged contacts. If you cannot get the contacts aligned, just try to get them away from each other and away from the wall of the port, then insert a piece of card or folded paper above and below the contact strip and tape them down. This will insulate the port and stop a reoccurance of the problem. You should find the computer starts (with a few complaints from windows) normally. this has worked for me 9 times out of 10 for this problem.
Good luck.
Apr 05, 2011 | ASUS A8F Notebook
I broke the connector from my cruzer usb flash drive. The silver connector is lost and now 4 wires are sticking out. Help!.
Try to backup the data you already have in it to a computer. Carefully insert the four wires and the remainder of what's left into a computer's USB port - be careful not to short any of the contacts together or to the chassis of the computer. Make sure the contacts are connected to their corresponding contacts in the USB jack of the input.
Nov 03, 2010 | SanDisk Computers & Internet
My usb drive was working properly now all of a sudden it is not being recognized. Please help I have some very important information listed
Check the contacts on the plug and make sure nothing is bent and the contacts are clean. Then try another USB port on the computer. Also, check the drive on another computer if it recognizes it - it may be your computer as the problem.
Nov 02, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
How to connect to another pc
Hi stephenwimbl.
Yes, you may connect another Computer by using the USB to USB PC cable.
The picture of the USB-USB PC Cable is displayed in the below link:
http://www.google.co.in/images?client=firefox-a&rls=org.mozilla:en-US:official&channel=s&hl=en&q=USB%20to%20USB%20cable&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1152&bih=649
You may contact for favorite Computer Retailer for more information about the USB-USB cable.
You may also purchase the USB-USB cable online.
Hope this helps.
Please feel free to contact for further information.
Sep 01, 2010 | Acer Aspire One PC Notebook
My computer cannot detect usb my computer model is 6bxa-61 samsung
You were saying that your computer could not detect any USB devices? Or just one USB device? Alright, you need to isolate the problem, follow the steps below:
1. Use at least 3 USB devices and connect them one at a time to the USB ports of your computer. If the first USB device is not detected, mark the USB port on your computer with "X" mark.
2. Now, connect the same USB device to another USB port of the computer. If you get the same problem, use the second USB device and connect it to the computer. If all 3 USB devices are getting the same problem connecting in all the USB ports of the computer (either on the front or on the back of the computer), then you need to update or re-install the USB driver to your computer.
3. Contact the manufacturer if the computer or the board and see if they could provide a USB driver for *********** board. Tell them what operating system (OS) you are currently running.
Have a great day!
Jul 24, 2009 | Computers & Internet
Operation of computer while connected to F380 .
Hai
I understand that your Isue is "After installing the HP All-in-One software, the computer stops responding during start up when the All-in-One is connected and turned on. The computer will start correctly if the All-in-One is not connected or is turned off."
SOLUTION:
This problem can be resolved by changing the "USB Emulation" in the Computer BIOS settings.
If you are using a DELL Computer just follow my instruction below.
Caution:
If you are using a USB keyboard, do not disable “USB Emulation”, “USB Keyboard Support”, or “USB Legacy Support”. If the settings must be disabled, use a PS/2 keyboard
Changing the BIOS on a Dell Dimension computer
Follow the steps below to turn off the ability to boot from USB devices but still support a USB keyboard while starting. Contact Dell for assistance if necessary.
  1. Shut down the computer.
  2. Unplug all USB devices other than a keyboard.
  3. Start the computer. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press the Down Arrow key to highlight Integrated Devices (Legacy Select Options).
  5. Press the Enter key.
  6. Press the Down Arrow key to highlight USB Emulation .
  7. Press the Space Bar until the “ No BOOT ” option displays.
  8. Press the Esc key twice to go to the Exit menu.
  9. Plug the USB devices back in.
  10. Ensure that “ Save Changes and Exit ” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Changing the BIOS on a Dell Laptop PC.
  1. Shut down the portable.
  2. Unplug all USB devices including USB keyboards.
  3. Start the laptop. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press and hold the ALT key while tapping the P key until a screen displays that includes the words “ USB Emulation ”.
  5. Press the Down Arrow key to highlight “USB Emulation”.
  6. Press the Right Arrow key until the “Disabled” option displays.
  7. Press the Esc key once to go to the Exit menu.
  8. Plug the USB devices back in.
  9. Ensure that “Save Changes and Exit” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Change the BIOS on computers from manufacturers other than Dell If you do not have a Dell computer, contact the computer manufacturer for assistance. If the manufacturer does not know how to disable starting from USB devices, they may be able to change the order (boot order) of the disks the BIOS uses to start the computer. Move the bootable USB devices selection lower on the list than the computer hard disk drive. If you have any further queries or if the problem still persists, reply me. Thanks Riz (jack_36623@yahoo.com)
May 20, 2008 | HP DeskJet F380 All-In-One Printer
Samsung Galaxy GT-S5570 Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
