Question about Hoover Washing Machines
Hoover 5.5.kgs washing machine
Water overflowing on cycles
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 1314 Answers
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
Illeagle
  • 525 Answers
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
Posted on May 24, 2008
IFIXALL
  • 868 Answers
SOURCE: hoover washing machine won't finnish cycle.
bad control board
Posted on May 26, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Hoover 700 LA keeps overflowing
Hi just read you posting.Now fortunately I have the same machine.Just a couple of questions.--1-- does the machine flood at the start of the cycle when it is filling for the wash or in the rinse cycle? 2---At anytime while it is filling does it start to wash? Now try this for me, Turn the machine on at the start of a cycle so it starts filling and then when you hear the water going into the machine turn the power off at the power point. After you turn the power off at the power point can you still hear water coming into the machine?Please reply with additional information to the questions because with those questions answered I will tell you the exact fault and guide you throe the repair.
Jun 20, 2010 | Washing Machines
My hoover washing machine won't spray rinse or deep rinse on cold
Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
Oct 23, 2009 | Hoover Washing Machines
Dishwasher overflows from front
Hi andrew did you get this fixed as it sounds identical to my problem.
Ian
Sep 01, 2009 | Hoover 24 in. HD83M Free-standing...
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Hoover 500M Top Load washer - Water overflow & machine wont wash
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things.
Fault could be caused by several possible faults at widely varying cost.
I suggest you call a friendly local white appliance engineer...
Feb 13, 2018 | Hoover Nextra HNT 2135 Top Load Washer
Purchase of washing machine
well...the hole less drum has more concentrated spin/wash water solubility. The hole drum has a more effective rinse release cycle. The holeless drums are usually used for higher weight loads, since the water penetration on those can be critical. Water capacity and usage are key to this choice. It all depends on the availability of clean water in your district.
Feb 10, 2008 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
