Question about Konica Minolta Office Equipment & Supplies
Batch print how can i configure to print batch number or its not possible?
  • Konica Minolta Master
  • 6,161 Answers
Can you print a receipt from the previous business day?
Only if it hasn't "batched" yet.
You can press the "Reprint" button (second from right purple button) to reprint the last receipt. You can also print any receipt that hasn't batched yet (normally from the current business day) by entering the receipt number. You can guess the number if you don't know it. Number 1 is the first transaction of the day, number 2 is the next one, etc.
If for some reason your transactions from the previous business day didn't get sent as a batch to the processor successfully, you would be able to print receipts for them. Otherwise, contact your processing company, and they should be able to send you a copy of the receipt.
Jun 19, 2014 | VeriFone VX510
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
Oct 19, 2011 | VeriFone VX510
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
My HP 940C only prints in shades of red. I replaced with new HP 15 & 78 Cartridges, still have same problem!
Some HP ink refills have the exact same product number but the electrical contact tips on the back of the cartridge are not the same configuration, resulting in red ink only being printed. One example is the DeskJet color ink cartridge C1823D having multiple configurations.Find a printer just like yours that's working properly and compare the contact tips if possible. HP tech help is a joke on this one. Good luck!
Dec 29, 2009 | HP DeskJet 940c InkJet Printer
Black or Blue not printing - just red and yellow
Are you using geninue Microboards new cartidges or refills? If you are using the new Microboards ink carts, then you have a bad cartridge, or possibly a bad batch. Simply call Microboards tech support at 952.556.1639.
http://www.techwaredist.com
Oct 16, 2008 | MicroBoards PF-2 InkJet Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Prints only a few pages
try to reinstall the printer driver..
good luck
Apr 03, 2008 | Dell Inkjet 720 Printer
HPLS2208 needs enter after scan
Check to see if there is a scan book that came with it. It will allow you to program the scanner to automatically read the code and enter after every scan.
Feb 25, 2008 | Symbol LS2208 Handheld
Two copies of the same image printed
Batch printing all images in camera memory while the camera's album generator feature is enabled, will cause such duplicate printing. This is because the album generator creates two images in camera memory: the normal image and a preview image. Batch printing all images will result in the camera printing both the normal image and the preview image. What you should do - Use the camera's DPOF settings to specify the images you want to print. Using DPOF is very simple, and it eliminates the problem of double prints. * See the User's Guide for details about DPOF image settings, specifying the number of copies, date stamping, etc. - The album generation feature also has a delete function for deleting generated album data, so you could also delete the album before batch printing.
Aug 30, 2005 | Casio QV-R62 Digital Camera
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
