Question about SEIKI Digital Seiki 32" Class 720p 60Hz LED HDTV - SE32HS01 Black 30 to 39 in
Lost all the channels ran auto scan but didn work 32" SE32HS01
May have for some reason need toput qam code in again
    Top Expert:
  • SEIKI Digital Master
  • 75,311 Answers
Check and replace its main system control memory IC, and re-program it with initial data. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 27, 2014
How can i get a QAM code?
QAM codes are to do with the way digital TV is encoded. There's nothing practical you can do with a QAM code. It's like understanding how to calculate the mass of Jupiter. Great that you can do it. But it's of no practical day-to-day benefit.
Here's some reading on Quadratic Amplitude Modulation, for what it's worth.
Comparison of 8 QAM 16 QAM 32 QAM 64 QAM 128 QAM 256 QAM Types
Sep 08, 2014 | Seiki Televison & Video
My tv will scan and receive channels on a antenna but will not pick up channels on a cable scan with a good cable and a proven good cable signal
if you are not using a cable box and trying to connect cable directly to tv you will get very few channels since they are all digital now and most are scrambled
you will need to hook that cable to the input labled 'QAM' and program tv for digital channels
if you are coming out of a 'cable box' you just need to hook up video cables to an input on tv and change tv to that input - no scanning necessary
hope this helps - if not write back with more details and i will try to help more
good luck!
Mar 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
Is there any way to remove channels after auto scan kworld sa295?
I stumbled across this feature by accident :-)
Press the "OK - Enter" button.
Your list of auto-scanned channels will appear.
Key in the channel number. Ex. 101-5
Then press the "Left browse arrow".
The channel number will now appear grayed.
To re-activate the channel just key in the number again and now press the "Right browse arrow".
Use the Up or Down browse arrows to page through the scanned list.
Oct 31, 2009 | Televison & Video
Scan No Longer Working
Do you have Verizon? The problem you are having is a long standing issue with Verizon. It was recently corrected for some of us. Certain TV's could not receive QAM channels, because of a Verizon caused issue. They blamed the TV manufacturer and the manufacturer blamed Verizon.
My TV's are Sharps, but I recall Vizio as also having the problem. Although it was fixed in my area MA, and in the Philadelphia area, other areas are still reporting the issue My problem disappeared shortly after the recent channel realignment.
Here is a link to a lengthy thread on the subject at the AVS forum;
http://www.dslreports.com/forum/r19439993-QAM-Changes-from-Philly-VHO
Jul 10, 2009 | Vizio L32 32 in. LCD HDTV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Feb 09, 2009 | Westinghouse LTV-32w3 HD Television
Eurovox max v help
telewest codes
KEY OO = 37 32 37 03 D0 73 84 84
KEY 01 = C6 64 1D EF 47 5A 0E EF
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Auto Scan
haha.......i am finding this really funny....because i am having that problem to and can figure out how to get it fixed.......
Aug 15, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
SEIKI Digital Seiki 32" Class 720p 60Hz LED HDTV - SE32HS01 Black 30 to 39 in Logo
71 people viewed this question
Top SEIKI Digital Televison & Video Experts
richie46
 Mikey
Mikey
Are you a SEIKI Digital Televison and Video Expert? Answer questions, earn points and help others
