Question about Hammering
Bosch jackhammer what causes my jackhammer to stop hammering and how do i fix it
  • 1,836 Answers
To long without service , or problem with a broken part ? or an problem with a electric field (slide contact somewhere ) or one of the carbon brushes is autostop activated ?
Or simple a cable break , a switch with a problem ,
Posted on Sep 12, 2016
My bosch jackhammer suddenly stopped working. What the most likely cause? stop
It probably went on strike to demand more money and/or more benefits.
Apr 25, 2017 | Bosch Hammering
Why my Bosch brute jackhammer only hums when I press trigger? Can someone help me please?
seems as if the jackhammer motor is locked up and frozen might wanna be careful opening it up and freeing that motor up while its unplugged
Apr 17, 2017 | Bosch Hammering
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Jackhammer is not hammering
Its need service if its anchor / drive gear is worn or the o-rings seals are worn, if its this model hammer make a trade-in service that in case its an old hammer like this model its not the model to service by your one the best option is trade-in by your dealer. if its handle this model
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
Mar 27, 2014 | Hammering
Bosch jackhammer
broken power cable or autostop inside the carbon brush they are short its time for a revision !!
Nov 28, 2013 | Hammering
How to fix jackhammer it doesnt hammer.
Bosch hammer drill 11304 uses sds bits and is generally a good hammer. Usually only needs yearly (depending on use) lube with Bosch grease to keep it working well. No hammering usually means lack of lubrication or broken connecting rod on the hammer piston. Not easy to repair. Tackle only if you have lots of experience with Bosch or other complicated hammers. Parts are easy to find. Good luck.
Mar 02, 2012 | Hammering
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Jan 30, 2011 | Electric Demolition Jackhammer
Hammering Logo
308 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
