Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Adjust blade belt on castelgarden twin cut
Blade belt slipping
My problem is with a Webb H12R-A manual lawn mower which has the blade set on the lowest setting possible but doesnt cut the grass
Are the blades turning when you lower the deck? If not, your belt may be slipping or it's off the pulley. Once you lower the deck and lift your foot off the the brake / clutch it should engage because the slack is now taken up on the belt, so slipping, belt jumped off or belt stretched out.
Aug 30, 2016 | Garden
Blade keeps slipping off.cant be put back on without spending 15+ minutes and a cut hand. Is there an easy way
There should be an adjusting knob to tip the upper wheel back and forth till you get it right to keep the blade tracking. This is similar in function to a belt sander adjustment.
To put the blade back on release the tension and carefully thread it though , wind the wheels manually, and gently guide it back in place, then reapply the tension.
Feb 27, 2016 | Blade Saws
How do I replace the drive belt?
Depending on which model you have, you will have to loosen the belt adjustment by the gear drive mechanism, then slip the belt over the drive pulley. This should allow enough room to get the belt over the blade and off. It might be easier to remove the blade too.
Then install the new belt over blade first then over drive gear box pulley, then tighten adjustment for the belt at the gearbox.
Jun 23, 2015 | Garden
Amada HA-250 horizontal band saw troubleshooting guide.
You can download free Amada manual on bandsawmanuals.com .
May 30, 2014 | Saws
My Husqvarna/Partner K 950 Circular Cut-Off saw drive belt slips on the clutch pulley whenever the circular blade is introduced to load.
I fear that the belt is slipping in the pulleys, the clutch is very unlikly to slip as it is a metal to metal contact, i have never had to fit a clutch due to it slipping, the K970 went on from the k950 and had a poly v belt and pulleys, you can retro fit the the pulleys belt and blade shaft, the loading on the standard belt is very high especially when using a 16" blade.
Oct 22, 2012 | Husqvarna Saws
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
We have Toro Lwa 100 Lawn Mower Model #26623. Power engaged, start mowing but lawn mower will not cut grass. You have to stop and let it rev up again to cut more grass.
This 1991-92 model is equipped with a blade brake clutch. When the blade slows down this means the belt is slipping. This slipping can be caused from a few different things.
Try adjusting the blade cable on the upper handle. this unit has an adjustable section. make sure the cable is not so tight that you snap it.
2 --A sticky pivot point under the belt cover
The belt cover in the back builds up with dirt and debris. Make sude it is clean under the cover and all of the pivots move freely. ( do this with the engine off)
3 --A sticky belt tensioner under the deck cover
The underside of this machine has a metal cover to protect the belts. Remove it and check that the blade belt idler arm is not frozen in place. this will cause the belt not to enguage all the way.
4 --A worn belt or belt pulley
The large flywheel and pulley can wear. Check this if the belt looks good.
This is all there is to the machine BBC system.
I hope this helps.
Get parts and more diagrams at a Master Toro Dealer like www.arcolawn.com
Jun 06, 2010 | Toro Lawn Mower With Toro Power Tools
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Blade stops turning but motor still running
Hi Lew 2!
Sounds like the belt might be slipping prematurely. I'd try cleaning the belt and all the pulleys with an alcohol based solvent or rubbing alcohol (clear) to remove any excess oils that might cause slippage and see if that helps Is there any type of belt tension adjustment? If so, also try tightening the belt.. If the problem persists, you probably need to replace the belt.
If this helps, after the churning stops, remove the paddles and cover the top with plastic wrap or wax paper and allow the mixture to "firm up" in the ice bucket nother 10-15 mnutes, and then enjoy a great old-fashioned treat!
Hope this is a help, let us know how it goes, and good luck!
-WB
Jun 14, 2008 | Simac Ice Cream Makers
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
54 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
