Question about HP ProCurve MSM310-R (J9380A) 802.11a/b/g Wireless Access Point
Msm 310 ethernet port 2
Ethernet port 2
2007 SRX pedals, adjustable quit, front drivers seat and both heater switches All quit at same time what could have done this? Passenger power seat still works?
Electronic's ! drivers Power seat module , driver door module . Do you know anything about automotive electronic's ?
The heated seat module (MSM) controls heated seat operation for both the driver and passenger seats. There are 2 modes of operation available for heated seats; both the seat cushion and seat back heat, or seat back only heat. When a heated seat temperature signal request is received, the MSM will activate both the seat cushion and seat back heating elements. When the heated seat BACK ONLY mode button is pressed once the MSM will deactivate the seat cushion heating element and leave the seat back heating element ON.
The adjustable pedal system is controlled by the memory seat module (MSM).
your best bet , have a qualified repair shop check it out ! Could have DTC'S - diagnostic trouble codes in door module , BCM etc...
Mar 15, 2018 | 2007 Cadillac SRX
2009 Buick Lucerne, power driver seat won't adjust on seat or through memory button. Passenger seat works fine. Heater for both seats won't turn on. Checked fuses and relays, all ok
Your best bet , have it checked for DTC'S - diagnostic trouble codes first ! Electronic control modules involved ! Can't check with a OBD 2 code reader , need advanced scan tool . No codes , check B+ voltage and ground to the module .
Power Seat Inoperative (With Memory A45)
Memory Seat Feature Inoperative
Circuit/System Description
Battery voltage is supplied at all times to the memory seat module (MSM) from the MDL-MEM 10A fuse located in the rear fuse block. This voltage is used by the MSM for logic power and to supply battery reference voltage to the seat and lumbar adjuster switches. Battery positive voltage is also supplied at all times to the MSM from the PWR SEAT 25A circuit breaker. This voltage is connected to a power rail internal to the MSM and is used to drive the power seat motors, lumbar motors, and seat heater elements on vehicles equipped with heated seats. Each seat and lumbar adjuster motor is controlled by the MSM through 2 motor control circuits. The MSM connects all motor control circuits on the power rail to a common reference point whenever they are not in operation. This reference point is biased to approximately 2.5 volts. The MSM checks to see if the reference voltage is shorted to ground or battery before enabling any of the seat or lumbar motors.
Reference voltage is supplied to the memory switch from the driver door module (DDM). When a memory switch is pressed, reference voltage is applied through the switch contacts, a series of resistors and thorough the memory switch signal circuit to the DDM. The door module then sends a serial data message to the memory seat module (MSM) indicating the memory recall request. The MSM then commands the appropriate seat motors to move to the pre-recorded seat positions stored in memory in response to the switch input.
Sep 02, 2017 | 2009 Buick Lucerne
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Gateway 310 s doesn't recognize network card
you may have to get access thru ethernet or dial up until all updates have been installed thru windows. After all updates try the network card again.
Nov 22, 2009 | Gateway 310 S PC Desktop
I am connecting 4 nodes through 2 switch located at 400ft distance. the data transfer is not working. 2 nodes are connected to each switch, both nodes connected to individual switch communicates with each...
Just to clarify, you have 4 computers connected to two ethernet switches. Two computers are connecteh to each ethernet switch and a network cable connecting the two ethernet switches 400ft apart.
For all the computers to communicate with each other, they all need to be in the same workgroup "name".
The cable joining the two ethernet switches need to be connected to the RJ45 UPLINK port on both the ethernet switches, and the uplink port may have a switch (the switch allows it to function as a standard RJ45 port or a RJ45 uplink port).
If there is no RJ45 uplink ports on the ethernet switches then a cross over network cable is needed to connect the ethernet switches together.
Oct 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Replacing an ethernet port on my hp pavillion
Your ethernet port is probably integrated into the motherboard of your computer. Have you tried reinstalling the driver for the ethernet?
If the port is truly bad, my suggestion would be to purchase an ethernet card or NIC (Network Interface Card) and have it installed. You can get them for $15 to $25 at any big box computer store.
Nov 04, 2008 | Computers & Internet
What do I need to use the P310?
You need a ADSL modem or cable modem with an Ethernet port to use the P310. The P310 has two Ethernet ports: LAN port and WAN port. You should connect the computer to the LAN port and connect the external modem to the WAN port. If the ISP uses PPPoE or RoadRunner Authentication you need the user account to enter in the P310.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
What is the Prestige 310 Internet Access Sharing Router?
The Prestige 310 Internet Access Sharing Router is a robust solution complete with everything needed for providing Internet access to multiple workstations through your cable or ADSL modem. The router equipped with 10Mbps Ethernet WAN port and an auto-sensing 10/100Mbps Etherent LAN port is the most simple and affordable solution for multiple and instant broadband Internet access. Virtually all-popular applications over Internet, such as Web, E-Mail, FTP, Telnet, Gopher, are supported. The Prestige 310 is designed for SOHO, branch offices, workgroups, and educational users.
HP ProCurve MSM310-R (J9380A) 802.11a/b/g Wireless Access Point Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
