Question about Haier L19B1120 - 19in Class 18.5in viewable LCD TV
The picture of tv Haier is black and white
Picture with DVD and local channel are black and white colors
3 Suggested Answers
  • 8457 Answers
SOURCE: i just reconnected my haier television to the
U are using a AV RCA cable for the connections?Ur AV RCA cable connections all matches up like RED to RED,YELLOW to YELLOW and WHITE TO WHITE?Tried another AV RCA cable?Might even tries a HDMI cable for the connections?U tried all these still getting the same result no colors,just black and white.Than ur Tuner board is defective,must be replaced to solved this problems.
Posted on May 14, 2010
SOURCE: my brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
My haier plasma monitor blinkred and than blue light..when you put the power it clicks frist 2 times and than 1 more time.please help.
Posted on Jan 17, 2013
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Black and white channels not color
I would suggest to you it is not the set if only two channels, perhaps the transmission is in black and white?
Apr 17, 2012 | Televison & Video
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Have an RCA console, color, 26" screen. Over 30 years old. Hooked up to cable and DVD player. Overnight the color disappeared and reception is black and white. Did color guns go out?
If you can see white, then all the CRTs are functioning. Make sure that the channel is set correctly. If the DVD is sending out channel 3 and the TV is set to channel 4, you will see the picture, but in B&W, Check that first. Let me know if that does not resolve it.
Thanks,
Dan
Mar 06, 2009 | RCA Televison & Video
Picture is black and white
If you have it connected to the 'antenna input' on your TV, change the channel up or down, and then back to 3/4 as appropriate. Sometimes the signal from the machine does not match exactly what the TV is looking for, but the TV will figure it out after you change the channel up or down. The AFC (automatic frequency control) will then try to re-tune the channel.
If you have it connected using the composite, and r/w audio, then you likely have a problem inside the DVR.
tom
Feb 16, 2009 | Protron PD-DVR100 DVD Recorder
No color output from philips 751/171 dvd player
Hello.
The RF modulator sends on a certain frequernzy(Channel) usally around channel 36 on UHF. If there is a adjustmen screw on it try and turn it util the picture disapears and then search for it on the tv again just to make sure nothing else is interfearing on the channel the RF modulator is sending on now.
An alternative if there is no adjustment on your RF modulator would be to change the frequenzy on your VCR or other devices attached to your TV that might send on the same frequenzy as your RF modulator.
Regards..
/Tech5508
Feb 15, 2009 | Philips Televison & Video
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
No color
switch the tv video formats PAL / Secam / NTSC ....
try them all and u will get the color
give me a good rate
Aug 16, 2008 | Haier Portable DVD Player PDVD7
Haier L19B1120 - 19in Class  18.5in viewable  LCD TV Logo
46 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
