Question about Asko W6021 Front Load Washer
I NEED TO SWITCH OFF THE DEMO MODE ON ASKO WASHING MACHINE
THE MACHINE START THE CISLE AND AFTER LOAD SOME WATER JUST STOP AND ASK TO SELECT PROGRAM AGAIN
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 351 Answers
SOURCE: Asko W6461 - will not drain
is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
Posted on Apr 09, 2008
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
Krazytech
  • 725 Answers
SOURCE: I have an asko wm200 washing machine. I have an F3
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
Miele w1913 simulation active on display when I press start/stop
Press and hold the Start/Stop button while switching the unit on with the On/Off switch.
As soon as the Start/Stop illumination ring lights constantly, after approx. 5 sec., release the Start/Stop button.
Immediately press and hold the Start/Stop button until the Demo-Mode is activated, approx. 4 seconds.
Demo-Program deactivation: Follow the instruction for Demo-Mode access above.
Aug 16, 2014 | Washing Machines
How make the door open automatically when finish the laundry
Welcome to FixYa,
These model of Asko ( based on the number listed ) do not have such an option. On these models the Program Control knob must be at the end of a program (at the 12:00 or zero position) to open the glass door.
If you need to stop or interrupt a program after you start the machine, turn the Program Control knob
to 10 (Drain). Any water in the machine will be pumped out and you can then press the Door Open
button ( ) to open the door. To restart the washer, close the door and turn the controls to the desired
settings.
On the electronic control models, if you need to open the glass door during a wash or rinse cycle, press and hold the Door Open button for three seconds. The machine will stop and automatically drain enough water so the door can be opened safely. The program will resume when you close the door. The inlet valve will come on to
ensure the proper water level.
In case of mechanical failure, you can use the Emergency Door Opener located by the drain pump. To use the Emergency Door Opener, remove the screw holding the cord handle (loop) and pull the cord down.
Hope this answers your question even if it isn't necessarily the answer you wanted. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Jan 10, 2011 | Asko W6021 Front Load Washer
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
Asko w6021 still not working
check that all the plugs are in the correct position on the board,you may have introduced the fault,because the only fault you had to start with was worn carbons.did you break off any links maybe J4 etc if the original board had the link taken off and you dont do it on the new board you will hard program the new board and will have to order another board. is the machine heating.put on wool wash and select heating you should hear it start to heat.let me know.thanks Ian
Mar 31, 2008 | Asko W6021 Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Jan 24, 2008 | Asko W6221 Front Load Washer
Not working washing machine
Sounds like it's either in demo mode or you changed something when you went into programe mode. Handbook should tell you about how to get in and out of demo mode.
Dec 23, 2007 | Miele Novotronic Premier 500 Front Load...
Asko W6021 Front Load Washer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
