Question about Canon Cameras
Error 69 Hi there. Can you please help me. I have massage for error 69 on my Canon EOS 30d camera? What does it mean?
    New Friend:
  • 24 Answers
Do you mean error 99? An error 69 is not listed in the manual. Error 99 mainly occurs with non-canon lenses, and indicates a communication problem between body and lens. Which still does mean nothing more than: it could be anything... Try cleaning the contacts. Or mounting another lens.
Posted on Jul 11, 2014
SOURCE: Canon EOS 30D will not operate
Hey Paul
I have the same problems, I just sent it back to Canon Service Center for repairs. I will see what is the outcome.....
Posted on Jun 12, 2008
informatica
  • 1114 Answers
SOURCE: I have a Canon EOS
Hi - You can download the manual from the link underlined in blue below:
Canon EOS 30D
For info on fixing error 99 see here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 16, 2008
jcdill
  • 121 Answers
SOURCE: Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Posted on Dec 26, 2008
  • 51 Answers
SOURCE: Error 99 on 30D Canon
Had this problem before and i found this guide online
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
  • 80 Answers
SOURCE: error 99 canon 30d slr camera
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked good luck have a nice day!!! :) :) :)
Posted on Apr 08, 2010
What happens when I get Error code 20 on a canon rebel eos rebel t3i 600d?
From the Canon owner's manual:
"Error codes 10, 20, 30, 40, 50, 60, 70 and 80: Shooting is not possible due to an error. Turn the camera off and on again or re-install the battery. Operate the power switch, remove and install the battery pack again, or use a Canon lens (p.32, 28)."
Jun 17, 2014 | Canon EOS 30D Digital Camera with 18-55mm...
How to set the Live view setting in Canon eos 30d
Even though there is a screen on the back of the camera the 30D is not capable of "Live View"
You can view your menus and pictures after they have been made not live view.
Mar 29, 2011 | Canon EOS 30D Body Only Digital Camera
The CCD camera canon eos 30d is dirty and the technician tells me I can buy a new ccd. This dirt is stuck. It's very noticeable when I take photos in clear sky .. Where sold CCD Camera Canon EOS...
If you have dirt on the sensor, it can be cleaned using special products. If you Google the words "how to clean an SLR sensor", you will find sites that explain the procedure with pictures and places where you can order the supplies needed. This is much less expensive than trying to replace the ccd sensor.
Nov 14, 2010 | Canon EOS 30D Body Only Digital Camera
Canon EOS 30D users manual
Hi!
Great camera... Get the Manual HERE!
Regards,
Pelu.
Sep 01, 2010 | Canon EOS 30D 8.2MP Digital SLR Camera...
EOS 30D - blue print light then dead
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom right of your computer screen or did you just yank out the cord?
Jan 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos 30D digital Camera. I
I FOUND A COUPLE OF SITES TO TRY FOR THE SOFTWARE. I DO NOT ENDORSE EITHER SITE, JUST REFER FOR YOUR USE. HOPE THIS HELPS YOU!
www.usa.canon.com/consumer/controller
PCDriversUpdates.com
arclight1217
Nov 04, 2008 | Cameras
I have a Canon EOS 30D camera that I got for chrsitmas and never used. I moved recently and the manual is not in the camera box. Great, I know. But the camera when I turn and try to take a picture is says...
Canon EOS 30D
Informatica
Aug 15, 2008 | Canon Cameras
Vivitar 6000CAF for Canon EOS doesn't seem to work on my Canon 30D EOS camera?
A more appropriate product is Suntax DRF14C for Canon 10D, 30D.
http://www.suntax.com.sg/DRF14.html
Apr 01, 2008 | Vivitar 6000AF for Canon TTL Ring Light...
Canon EOS 30D SLR Will Not Turn On...
I seem to recall hearing that the power switch can be a problem on the 30D .. I'm not going to suggest you take it apart to clean the contacts .. better go to a Canon Dealer I think ..
Mar 31, 2008 | Canon EOS 30D Body Only Digital Camera
Cameras Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
