Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Machine not booting c- 0501
Not driving the fuser unit
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Would suspect issue with fuser.
Posted on Nov 14, 2014
2 Suggested Answers
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
HI.How can i reset a copier minolta konica bizhub36?
  • Code: 0501
  • Description: Fusing heaters trouble (edge)
    • Detected temperature of the heating roller thermistor (TH2; edge) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started.
  • Remedy: 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit CN30-PRCB CN16, fusing unit-relay CN4AC-DCPU CN2 for proper connection and correct or change as necessary. 4 Change fusing unit 5 Change PRCB 6 Change DCPU
This is from manual, try to reset trouble code:
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Hope it helps
May 29, 2017 | Minolta Office Equipment & Supplies
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
The machine reported problem with Fuser unit and all the four drums at once.
remove all consumables, turn off and leave off for 10 secs, turn on allow the machine to turn over at which point it will ask you to install the consumables, - install 1 at a time then close the doors , allow the machine tostep further and ask you again to install the next unit- this process will change when you get the faulty unit and try to insert, the machine will complain about all the consumables again- now you knowwhich part is faulty- replace -job done
Mar 12, 2014 | HP Office Equipment & Supplies
What does code c-3101 mean on a bizhub c353
C3101: Fusing Pressure Roller pressure/retraction failure
hi,
open the fuser unit out of the machine and you may find that the gear which drives the fuser unit at the behind which retracts the pressure roller must have been broken. This gear is located at machine frame where the fuser sits
Jan 05, 2010 | Konica Minolta bizhub C250 All-In-One...
MACHINE GOES OFF WHEN IT STARTS TO BOOT
Describe correctly whenever is the paper jam.If in the transfer section change the transfer/separator corona wire,and clean the sincron roller.If the paper is blocated in the exit parts,check the fuser unit parts and verify the exit actuator(located in the fuser unit).
Nov 05, 2009 | Minolta Office Equipment & Supplies
C350 malfunction code c-0501
Oct 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
The wheel at the end of the drum broke. mita machine #kt47. do I have to replace the drum? at least i think it's the drum,its the roller with wires attached at each end. the machine code # 199307
It sounds to me likeit is your fuser unit.
Depending on the model you can either replace the fuser drive gear or replace the entire fuser unit.
Get your local service agent to look at it
Jul 03, 2009 | Kyocera Mita Office Equipment & Supplies
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
