Question about HEWLETT-PACKARD LaserJet M5035x All-In-One Printer
M5035 cold reset
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Power off; power on holding the check mark/go and the job cancel button. all lights should flash, then ready......cold reset. yes ?
Posted on Aug 03, 2014
Password in motherboard m5035
Cold reset requires no password. Go to the machine and turn it off. Power it on and when the memory count starts, hold down the 6 button on the keypad. Hold until all three leds turn on and stay on. Release the 6 button, press the 3 button until display reads "cold reset", press 6 once more and printer will restart.
Apr 16, 2014 | HP LaserJet M5035 MFP Printer
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Won;t reboot after doing a cold reset on the machine
Why did you do a cold reset? If it was because the printer would not initiate, then you have a defective formatter board.
May 11, 2011 | HP LaserJet M5035 MFP Printer
Hi, I need to reset my Printer using cold reset option. please help.
? Cold Reset
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make a note of the IP address that is listed on the Jetdirect
page. You must restore the IP address after performing a cold reset.
Use this item to unlock menus that have been previously locked and to set all control panel menu
items (including EIO settings) back to the factory defaults. However, using this item does not clear
the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset, print a menu map and a configuration page.
Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
Apr 14, 2011 | HP LaserJet M5035 MFP Printer
Hi Expert. I need to reset my printer ist hp m5035mfp plase I need you Help
Blow are the steps to do a "cold reset" on your HP m5035 MFP Printer. Just be reminded though that you will lose all stored info on the printer and it will restore it to factory settings.
How to perform a Cold Reset:
1. Turn the off the device.
2. Turn the device on and immediately hold down the 6 button on the control-panel keypad as soon as the control-panel display backlight illuminates.
3. Continue to hold down the 6 button until all three control-panel LEDs remain illuminated. Release the 6 button.
4. Use the 3 button or the 9 button to scroll to Cold Reset.
5. Press 6 to select the Cold Reset function.
The unit should then restart.
Hope this helps.
Apr 14, 2011 | HP Office Equipment & Supplies
I need to reset default definition for this Printer. regards
If you are looking to factory reset, then what you need to do is turn the power off, turn the power back on, when the memory count starts, press and hold the 6 key until the three leds on the control panel stay on solid. Press the 3 key until "cold reset" shows in the display and then press 6 again. Unit will start up and factory defaults will be loaded. In some cases this will not clear the set network settings for the printer but it does get all other settings to factory.
Apr 13, 2011 | HP LaserJet M5035 MFP Printer
How do I create a quick access folder on the hp laserjet m5035
hi
it there in user manual
just refer you manual u will gind you solution
Jun 15, 2010 | HP LaserJet M5035 MFP Printer
IS THERE A PROGRAM TO DOWN LOAD FAX NUMBERS FROM A COMPUTER DIRECT TO THE HP M5035 MFP?
Fax numbers can be imported by csv file to the embeded web server of your M5035.
Steps
1.Export a csv file from Microsoft Outlook contacts. From file menu choose Import and export choose export to file then next, choose comma separated values then save to file location.
2.Next open the embeded web server (type the IP address eg. 19x.16x.0.10x in the address bar of a web browser).
3.Choose the digital sending tab at the top of the page.
4.Select address book on the left side of the page.
5.Then click browse and select the file saved in step one.
6.Choose import.
This will import the csv list of fax numbers into your M5035
Jun 10, 2010 | HP LaserJet M5035 MFP Printer
HEWLETT-PACKARD LaserJet M5035x All-In-One Printer Logo
37 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
