Question about Freezers
Vapor coming from bottom of inside freezer and water to dispenser frozen
My side by side freezer stopped cooling and coils had frozen. Also water to dispenser had frozen. Dispenser started to work after freezer was switched off for night.
    Problem Solver:
  • 4 Answers
The most common cause of this is a dirty condenser coil. Find the condenser coil for the unit , it will be under the freezer, in the back or ,in some models, on top. It will have a fan behind it. Shut of the unit and clean it. First with a paint brush to remove heavy dirt, then with a spray coil cleaner--this may get dirty, so be prepared with a mop. Clean it thoroughly without getting electrical components wet. (If you get anything electrical wet, make sure you allow ample time to dry before energizing it).
Posted on Mar 30, 2014
duby1990
  • 370 Answers
SOURCE: Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Posted on Nov 19, 2008
jumptrout51
  • 3361 Answers
SOURCE: Evaporator coil in freezer red hot and water dripping on it.
This normal operation. Happens twice a day to defrost the freezer coils. Last about 20 minutes.
Posted on May 02, 2009
SOURCE: LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Posted on Feb 10, 2010
SOURCE: Our BEKO AP930 fridge freezer ice maker stopped
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Posted on Feb 14, 2010
  • 141 Answers
SOURCE: bosch upright freezer ice maker and water
hello many times when the water and ice stop working you are not getting water to your freezer. so a few things to check if you have a water filter behind the freezer check for a blocked filter next. where the water line hooks up to the freezer there is usually a screen . turn the water off and remove the water line and check the screen if that s all ok it maybe the water solenoid hope this helps if not get back with me pls jason
Posted on Jun 09, 2010
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
I have recently purchased an 14.9 cubic foot chest type freezer after the delivery I plugged in the unit and left it runnig for about an hour and lifted the lid to check it out and felt on the inside of...
Good day,
That is totally normal. 24 hours is a good test period, and your model may not have refrigeration coils equally on all sides.
Smart to place a paper cup on the bottom center of the machine, half full of water.
When frozen solid, your good to go.
Aug 31, 2010 | Kenmore Chest Freezer 16922
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice Maker is dead on Kenmore Elite TRIO bottom freezer with French doors. This model has separate water dispenser inside fridge on left and ice maker in bottom freezer. We've tried replacing the filter,...
you can check the fill tube in the freezer make sure it is not blocked with frozen water. if you can disconnec the water supply line from the fill tube try and reset the ice maker to advance it to a new cycle and if water come out of the supply line the you knwo there is a blockage if no water comes out the the ice maker may be bad or the fill valve is bad. last thing you may need to call a service tech out to find the problem.good luck i hope that this has helped some what.i would like to knwo how thing go for you
Jan 22, 2010 | Freezers
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Sep 15, 2009 | Freezers
My side by side refrigerator leeks water from somewhere in the freezer and freezes at the inside bottom of freezer i have to hit it with a hard abject to break ice and remove at least onece a week
there is a defrost drain just below the coils in the back of freezer. check for blockage or may be frozen inside hole. hairdryer will do the trick but be careful..will melt the plastic if not careful.
Jun 11, 2009 | Freezers
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
83 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
