Question about Compaq Computers & Internet
Sync:out of range
When i boot my computer,it tells me sync out of range.What can i do?
  • Compaq Master
  • 1,087 Answers
Can you give any more details? Does anything else come on screen before that message?
Try this site which deals with the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&docname=c00061509
Posted on Mar 27, 2014
How do I sink it with my iphone?
if the instructions do not tell you then I would assume they are not compatible to sync
Nov 19, 2015 | Exercise & Fitness
Tells me iPad is disabled
Connect the device to the computer with which you normally sync and open iTunes. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes by pressing the "Back Up Now" button. When the backup and sync are complete, restore your device
Sep 26, 2015 | Apple iPad Mini
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
Sync out of range
start the pc and get Sync out of range problem...i changed resolution but still the same..I have Samsung 753s and radeon 9800
Jul 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I can not get my enV2 by LG to sync up to my PC...? I have downloaded the new driver and software... my PC says its good to go...but my phone is telling me connect failure... please check your cable...
reboot your computer (phone not connected) while computer is rebooting, cycle your phone off and back on, once the computer has fully booted (all start-up apps started) connect the phone, allow the computer to find it, follow onscreen instructions if given.
I use windows mobile sync on my system, have had no problems.
Feb 08, 2009 | Cell Phones
Must re-boot to sync phone to computer
you may contact the service provider.......
Dec 19, 2008 | Nokia 6822 Cellular Phone
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
Display sync out of range
start the computer in safe mode.
go to control panel>>display>>settings>>advance.
reset the screen refresh rate back to 60Hz under the monitor tab.
Nov 17, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Sync out of range
If using windows, boot to safe mode, and make sure your resolution is low enough for your monitor to handle.
Check your cables to make sure there are no broken pins.
Sep 16, 2008 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
