Dual channel 775i65g
MEMORY HANG
2 Suggested Answers
Semi-Driver
  • 434 Answers
SOURCE: Will P4M80-M4 motherboard support dual channel memory?
This is an older board. The VIA chipset pre-dates dual channel memory support. If your board is working fine, this should not be a concern.
Posted on Jan 08, 2010
Testimonial: "Helpful and quick response Thanks"
download drivers for your motherboard or your sound card
Dec 21, 2013 | Computers & Internet
PIG3IT VI.0
Is this a Mercury motherboard? And is that P 'eye' G3 'eye' T?
Or P L G3 L T?
What is the question?
Ya know Dual Channel memory is overrated, right?
If a motherboard is capable of using Ram Memory in a Dual Channel configuration, it has two Channels.
Motherboard with 4 Ram Memory slots has two slots in one channel, and the other two slots in another channel.
The two ram memory modules ('Stick'), MUST be alike.
Same frequency rate ('Speed')
Same type
Same ram timings
Same chip configuration
Same voltage
This is why it is best to use two ram memory modules that are alike, AND from the same ram memory manufacturer.
When ram memory is used in a dual channel configuration, the two ram memory modules team up on the task.
Kind of like Batman and Robin.
ON paper it looks good. many thought they were getting an increase of up to 30 percent, in ram memory performance.
In reality it is more like 1 to 2 percent.
Tomshardware performed MANY tests, using MANY motherboard/processor/ram memory configurations, and found this out.
So why do gamers use Dual Channel configuration?
Hey, 1 to 2 percent IS an increase, lol!
EVERY little bit helps.
Post back in a Comment.
Regards,
joecoolvette
Dec 22, 2012 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
Acer aspire m5100, AMD Athlon 64bit x2 dual core processor 5000+ 2.60Ghz. Win Vista Business 64bit. When i upgrade and put more than 3GB of ram into the machine, it turns off the lan and my display driver...
Acer official site says:-
Up to 4 GB DDR2 533/667/800 MHz SDRAM
(dual-channel support on four DIMMs)
Try these bus speeds and for dual-channel support read this article :-
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Dec 06, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
I'm Confused about Dual-Channel, How to Activate/Enable it?
Check your user manual for the type of memory you can use. If your computer could use dual channel memory, I think it would come that way. Dual Channel is a pair of special compatable memory modules and only come in pairs. To buy two unpaired memory modules and hope to run them as Dual Channel is wishing too much. If they work, you're lucky, but most likely they will not work as dual channel.
If you are using those two different memory modules and they both work for a total of 3 GB then you can not do much better.
How many memory slots are in your Asus G1 notebook?
Jun 14, 2009 | ASUS G1 Notebook
775i65G does not work when two 1GB DDR400 are installed.
I would venture to say one of the memory modules you have is bad..
Jan 25, 2009 | Asrock 775i65G Motherboard
It doesn't turn on
Try to reset the CMOS, remove the Battery on your motherboard, its like a silver flat coin, or if you can locate the RESET Jumper, just move the jumper to short. Then try booting-up your system again.
I hope this procedure will help you.
-mrsolution
Jun 11, 2008 | Asrock 775i65G Motherboard
Ram support
As much as I would love to spend a couple hours making you a list of Ram that your board supports, not happening.
However you can do this your self by looking in your manual.
Download your manual here:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1863
Go to the top of page 15.
Your board requires a voltage of no more than 2.5v
GA-8IPE1000 Series includes 4 DIMM sockets, and each Channel has two DIMM sockets as following:
Channel A : DDR 1, DDR 2
Channel B : DDR 3, DDR 4
If you want to operate the Dual Channel Technology, please note the following explanations due to the
limitation of Intel chipset specifications.
1. Dual channel memory cannot be used if one DDR memory modules are installed.
2. If two DDR memory modules are installed (same storage capacity), one must be added to the
Channel A slot and the other in the Channel B slot in order to use dual channel memory. Dual
channel memory cannot function if both DDR memory modules are installed on the same channel.
3. If four DDR memory modules are installed, please use memory of the same storage capacity in
order to use dual channel memory and for BIOS to detect all the DDR memory modules.
We'll strongly recommend our user to slot two DDR memory modules into the DIMMs with the same color in
order for Dual Channel Technology to work.
You board supports this type of memory:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-16
Or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1717669&CatId=1352
Good Luck & kind Regards.
& please vote.
Mar 16, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
