Question about SecuGen Hamster IV Finger Reader
Finger cracking - SecuGen Hamster IV Finger Reader
My Jeep Cherokee Laredo 1993 suddenly started making loud noise and steering got tight after driving it hard
the fluid for the power steering has ran out...fill it.usually located in the dashboard, near the steering wheel....
Oct 15, 2014 | Cars & Trucks
Signs blown head gasket
Cracked head means replace your engine, head gasket if you do it yourself approx $150 , dealership cost $800. Remove the oil cap on the top of the engine block , put your finger in and see what color the oil is if it's dark it's not a cracked head , if it's white and or milky looking, you have water in your oil, cracked head !
Jun 29, 2013 | Mazda Cars & Trucks
My tablet wont sense my finger,screen crack
have a tablet pc and my daughter fell and tablet cracked well screen did where to get it fix..
Dec 28, 2012 | Tablets & eReaders
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
IFit treadmill won't turn on. There is power to the plug.
Dear Sir:
Thank you by you request, I hope everything is fine.
I will try to help you.
Do this :
    • 1
Lookat the circuit to be measured, in this case I chose to check an outlet. In thiscase I need to check if an outlet is live.
    • 2
Keep fingers behind the fingerprotectors Thevoltage in a house circuit will range from 120 Volts in the wall outlets, to220 Volts at the range and dryer outlet. Both of which can kill instantly. Thisis where extreme care and safety must be observed. Inspect leads and probes fordamage and cracks. If any damage or cracks is found DO NOT USE, THROW AWAY!!!Keep fingers behind the finger guard as seen in the picture.
    • 3
200 Volts AC scale Choosea range which exceeds the voltage you expect to measure. You will need tochoose the AC scale.
    • 4
Measuring wall outlet to test forvoltage.
Thank you in advance,sincerely. Blessing.
If you need further assistance, please reach me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Oct 02, 2011 | Exercise & Fitness
I have a 1995 katana that wouldn't atart. i replaced the spark plugs and it starts now, however, there is a mist of oil that sprays out of the left exhaust pipe
It sounds like you have a crack in the Cylinder Head or worn valve guides that allow oil into the combustion chamber. If you start the bike and check that all the exhaust pipes are heating up at the front of the cylinder block you can make sure it's running on all cylinders.( Just spit on your finger and a quick dab on each pipe will tell you!) If it isn't then it's more likely the head is cracked or head gasket blown.
I accept no resposibility for burnt fingers. Safe Riding!
May 06, 2011 | Suzuki GSX 600 F (Katana Motorcycles
The screen is cracked how do i know if it still works the sceen had a crack about the sise of the nail on your pointer finger
plugin it in and see if it wil sync to your computer. If so it probably still works.
Check out the link below to get the cracked iphone screen fixed.
Cracked Iphone 3G LCD Screen Repair
Nov 17, 2009 | Apple iPhone Smartphone
Brakes
First bleed the MC, Remove the brake hose - block the outlet of the MC with your finger - pump the lever and crack you finger loose for an instant to bleed the air out - repeat til only fluid comes out. Quickly install the brake hose. Bleed the brakes by cracking loose the brake hose bolt. Bleed at the caliper bolt. Bleed as normal with the bleeder valve.
Nov 10, 2008 | 2002 Yamaha WR 426 F
Power button
get a screwdriver and pry it out IT WON'T CRACK!!!!
Apr 01, 2008 | Sony PlayStation 2 (PS2) Console
SecuGen Hamster IV Finger Reader Logo
Top SecuGen Office Equipment & Supplies Experts
jasbo
jasbo
Are you a SecuGen Office Equipment and Supply Expert? Answer questions, earn points and help others
