Question about Brother MFCJ5910DW: MFC-J5910DW All-in-One Color Inkj
Opening the case to change power supply - Brother MFCJ5910DW: MFC-J5910DW All-in-One Color Inkj
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • Brother Expert
  • 234 Answers
Its not difficult actually. Just unscrew what you see and the power supply is on the left. there should be 2-3 screws not visible enough :) and take out also the 2-3 cables that are visible enough. The PS is pulled from the down site to be replaced
Posted on Aug 01, 2014
Wiring new A/C
you should not have to run a double wire to the thermostat and the power supply. you should be able to come from the power supply and wire the supply and then the other to the t-stat but do get a second opinion. watch the color coded wires though manufacturers changed them to confuse the d i y er
Dec 24, 2014 | Dometic Heating & Cooling
Connecting power supply to motherboard
Hi There
This guide was developed to instruct readers on the proper procedures for installing a power supply unit (PSU) into a desktop computer case. It includes step-by-step instructions with photographs for the physical installation of the PSU into a computer case.
IMPORTANT: Many name brand manufacturer PCs use specially designed power supplies that have been built specifically for their systems. As a result, it is generally not possible to buy a replacement power supply and install it into these systems. If your power supply is having problems, you will likely need to contact the manufacturer for repairs.
CAUTION: All power supplies contain various capacitors inside of them that retain power even after the power supply had all power turned off. Never open up or insert any metal objects into the vents of the power supply as you can risk electrical shock.
To start with installing a power supply, it is necessary to open up the case. The method for opening the case will vary depending upon its design. Most new cases use either a panel or door while older systems require the whole cover be removed. Be sure to remove any screws fastening the cover to the case and set them aside.
Align the new PSU into place in the case so that the 4 mounting holes align properly. Make sure that any air intake fan on the power supply that resides in the case is facing towards the center of the case and not towards the case cover.
Now comes one of the most difficult portions of the power supply installation. The power supply needs to be held in place while it is fastened to the case with screws. If the case has a shelf ledge that the power supply sits on, it will be easier to balance.
Make sure that the voltage switch on the back of the power supply is set to the proper voltage level for your country. North America and Japan use 110/115v, while Europe and many other countriesuse 220/230v. In most cases the switch will come preset to the voltage settings for your region.
If the computer already has the motherboard installed into it, the power leads from the power supply need to be plugged in. Most modern motherboard use the large ATX power connector that gets plugged into the socket on the motherboard. Some motherboards require an additional amount of power through a 4-pin ATX12V connector. Plug this in if required.
A number of items reside within a computer case that require power from the power supply. The most common device is the various hard drives and CD/DVD drives. Typically these use the 4-pin molex style connector. Locate the appropriate sized power leads and plug them into any devices that require power.
At this point all of the installation and wiring should be completed with the power supply. Replace the computer cover or panel to the case. Fasten the cover or panel with the screws that were previously removed to open the case.
Link with Photo
Dec 12, 2011 | Computers & Internet
Desktop not receive a current
If you mean Power, then your psu (power supply unit) has most-likely gone bad. This happens a lot when a computer is as old as this model is. If you have no other choice than to replace the power supply, be sure to use dell in the search, models of this era did not have an opening on the back to accommodate a power (on/off) switch so you must get a replacement that will fit the case and not need an opening where there is not going to be one.
If you meant anything else, you need to explain better.
Nov 27, 2011 | Dell Dimension 8200 PC Desktop
Need a 200W+ power supply for a HP774y Pavillion Desk Top computer. It must have the dimensions 4 x 3.5 x 6 ish. the cables must come out on the right side (when viewing the fan opening side. Neither...
FixYa is a product support website, and not a manufacturer. No we do not have the part.
From a quick search this website does,
http://www.supernotebook.com/power-supply.php?psupart=1153?psu=FSP200-60SPV-D-774YCTO
[ If it were I, I would change the computer case, so I could use a standard ATX form factor power supply.
Cheaper, more reliable, more wattage, and high quality MosFets, Capacitors, Rectifier Bridge, and other associated SMPS parts are used.
{Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Plus you'll have better air flow, more capacity for drives, and etc.
What do you think of this one?
http://www.directron.com/cs888uvbl.html
Just a thought ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 22, 2011 | HP Bestec ATX-1956D 200w HP Part No...
Need a 400W power supply for a HP774y Pavillion Desk Top computer. It must have the dimensions 4 x 3.5 x 6 ish. the cables must come out on the right side (when viewing the fan opening side. Neither...
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
The computer suddenly shut down & will not re-boot. On turning on there may be a few seconds to allow option of opening up in safe mode which is applied but within a few seconds the system shuts down...
Bad Power Supply.
Weak voltage power rail.
One of the leading causes of computer failure.
Replace the Power Supply.
[The next cause of failure is the computer is dirty inside, as well as inside the Power Supply's case.
Dirt, dust, etc, takes a Power Supply down quick ]
Need guidance of how to replace your Power Supply, or guidance in finding a decent replacement Power Supply let me know in a Comment.
Regards,
joecoolvette
Dec 02, 2010 | Packard Bell Computers & Internet
My iomega 1tb external hard drive accidentally plugged the 110v to 220v and its stopped working. My i omega is dead and no light, how do I fix this
At the least it will be a new power supply. Does it have an external PSU or is it internal? It depends on the quality of the power suply wether any further damage was done.
Either way if you need the data you could open the drive case up and remove the drive from it, you could then fit it as an internal disk on a desktop PC to get the data back. Opening the case won't matter as you have voided any possible warranty by changing the supply voltage.
May 25, 2010 | Iomega (32453) External ZIP Drive
No power comming out of any of the conectors
Sounds like a blown fuse. You could replace that, but opening the power unit will void your warranty and the unit itself might be damaged as well. My advise would be to buy a new one unless you really know what you're doing, a half-broken power supply could damage other hardware or even start a fire (worst case scenario).
Aug 16, 2009 | Antec TP-550 550W ATX12V V2.3 / EPS12V...
No power what so ever!!
power supply could be dead in which case buy a new power supply, unless the motherboard is dead.
Mar 23, 2009 | E-Machines W3050 PC Desktop
Apple g4 digital audio Power supply API-9841
Solution: Replace power supply with a new one. Anything else might cause equipment damage, personal injury or death.
Any attempt for component level repair is not for the novice tinkerer. remember, opening the power supply might kill you.
My suggestion is to have the failed power supply module replaced with a brand new supply by a qualified repair technician.
Jul 24, 2008 | Apple G5 Case with Power Supply (p/n...
Brother MFCJ5910DW: MFC-J5910DW All-in-One Color Inkj Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
