Question about Candy FP855 Electric Single Oven
Set time How. Do I sett the time on my candybovdn after I have turned the power witch in on and of. It. Is. Showing auto
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
Will not stay on!!! the timer unit has the A symbol showing and unable to get it off, when you try and set the time by pressing the ready time and cook time buttons simultaniously the the minus button the...
You need to check that when you turn the automatic off, there is no time remaining in the cook time. You need to ensure that this is set to zero when cancelling the auto function.
If this still doesn't worh then espares will be able to source a replacement clock for you.
Mar 18, 2011 | Stoves 720EF Electric Double Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
How do you set the clock on an electrolux premier built in single oven after a power cut as time is flashing and auto is showing and only four buttons and no instruction manual.
hold down the first two buttons on the far left then turn the little diel button,this will set the time.also you can set the timer useing one button hope this helps roscargou.
Feb 15, 2010 | Electrolux Ovens
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Oven not heating
If it has a digital timer, make sure it is set to auto and not manual, as oven will not heat if it is on auto.
If it is a anolgue timer ,then it should be showing a hand symbol,if it is not, then turn knob or dial until it does.
If these settings are o/k, then could be a faulty element.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Dec 09, 2007 | Neff U1661 Double circotherm super...
Candy FP855 Electric Single Oven Logo
21 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
