Question about SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I take apart the casing
Trying to take cover off to see what is loose.
How do I open toshiba ct-90287 case to dry buttons
I guess this is a remote control.
Remove the batteries and look around including inside the battery cover for any small screws.
Remove all screws - Even If there isn't any screws.
Next>
You need a fairly wide but thin flat bladed screwdriver to split the case. Place the blade of the screwdriver between the two casings of the remote control and gently twist the blade and the case will begin to split apart. work it loose - but don't foce it apart. Apply even pressure around the remote control with the blade of the screwdriver.
Once you have seperated the two halves - clean the rubber buttons with either Meths or Isopropyl Alcohol and also clean the circuit board with the same where the buttons make contact with the circuit board. Then reassemble. Your control should then be ok!
Jun 22, 2011 | Televison & Video
My yukon sightmark sm650 rangefinder laser is not working.The golf shop sold me a "Parview LS650" after looking around the internet, it looks exactly like the sm650. To my question....the laser...
Take it apart by peeling away rubber cover and then remove two mounting screws. Carefully split cases and see where parts are arranged just in case they shift. Laser and lens frequently get jarred loose ESP in a golf cart environment. Place laser and lens if loose back in mounts and gluon in place with superglue or equivalent. Make sure to get no glue on lenses. Reassemble and it should be good to go again. Total time. Ten minutes maybe.
Jun 09, 2011 | Yukon SightMark SM650 Rangefinder
I am trying to change the clutch cable on a 07 xb12ss and a piece fell into the crank case. how do i remove the cover so that i can retreive the part this is such a poor design whats the best way to get it...
Not a poor design, if you dropped something down inside of a say Honda - you would be splitting the cases to get it out. On the Harley/buell motor you just loosen all of the allen head bolts and remove them and remove the shifter assembly and pull the inspection cover off. pull the next set of bolts if you want to remove the whole cover.
Sep 11, 2010 | 2007 Buell Lightning Long XB12Ss
Where are the screws/tabs that hold the kenmore 25513 case together? The vacuum makes a "clicking" noise like a relay is kicking in but the motor will not turn on. I suspect siezed bearings.
The screws that hold the cover are under the spring loaded "bar" for retractng the cord. To get at the screws one has to pry the bar loose! The problem with the motor is that something fell apart within it (small bolts fell out).
I do not see any non-destructive way of taking the motor apart.
Dec 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
How do i remove my crank case cover on my 07 r1 apart from removing the alan bolts the clutch cable goes through thr cover. how do i get it out without messing stuff up?
its hard to understand what you are trying to do.. it seems to me that you are trying to get the clutch cover off?? when you take the 8mm bolts off the cover should just pull off and there is nothing that wil fall off get back to me if you have any questions
Aug 15, 2009 | 2007 Yamaha YZF-R1
Bobbin tangling
Sounds like the bobbin is spinning to fast or is winded to loose. Try adjusting the tension on the bobbin.
May 05, 2009 | Sewing Machines
Inside of PC is extremly dirty!
There should be a gray button type thing on the top of the back end of the case and the bottom. You will need to push both in at the same time to get the case open. Push both in and slide the case apart. I found that having somone pull the case apart while i push on the buttons is easier.
Let me know if how it goes.
Regards
Dec 13, 2008 | Dell Dimension 2400 PC Desktop
Brother XL-6562 Mechanical Sewing Machine
Dear jbanistr,
My wife and I just had this same problem (or at least getting the cover off) and have a possible solution. Safety first, unplug your machine from the wall. Next remove all the screws, three by handle, three on the bottom, one on the rear of the sleeve arm, one on the light bulb cover and one inside the lightbulb cover that goes sideways into the frame. I believe that's all of them but look for any that hold plastic-to-plastic or plastic-to-metal. Take note not to change the stich settings or else you'll have to find and set the number wheel and the adjuster to match, not fun. The way we did it was starting from the top, pry the case apart slightly and with a flat screwdriver gently lift the case over the three adjusting wheels so they clear. We then, with difficulty, pried the case the rest of the way open, with a really loud pop! A better way might have been to start pring from the bottom, but it worked. Reassembly was just the reverse, just fit the top first and put all those screws back in.
Hope this helps.
Sep 06, 2008 | Brother XL-6562 Mechanical Sewing Machine
Broken Lens Cover Mechanism
I would caution against trying to take cameras apart. Take it to a repairer who has the tools, knowledge and experience to do it properly. They also check timings and metering.
There are some resources here, and also look at the video tab.
Kalimar Cameras Google Search
Mar 17, 2017 | Kalimar Cameras
SkyGolf SkyCaddie SG5 Car GPS Receiver Logo
27 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
