Question about AT&T 1738 Digital Answering Machine
Cuts off message in the middle
When recording a message, machine will sometimes (about 20% of the time) cut it off in the middle, even when machine is not full. This can happen when it is the only message, but especially when call is made from a cell phone. When I try to retreive it remotely, it plays only part of the message and then you can't get any messages after it either. Sometimes hitting 4, then 1, or 4, then 2, will get it unstuck and it will play. Or, calling back later sometimes does the trick. I had an old (10 years) machine that did this so I bought  a new one and it does exactly the same thing. When I go to the machine, it plays fine, but this is impractical. What can I do about this short of buying another brand?
    Problem Solver:
  • 13 Answers
Re: Cuts off message in the middle - AT&T 1738 Digital Answering Machine Answering Machines
Buy another machine
Posted on Nov 01, 2008
0 characters
3 Points
A caller hears my announcement but the machine cuts off before a messages can be recorded
There a chance your machine recorded too many messages, which actually means, the memory is full and should be cleaned / wiped.
Check the manual or download it here and see for page 5 at subtitle deleting messages.
Nov 17, 2011 | AT&T 1717 Digital Answering Machine
How do I change the message... we set it a few years ago...can't find book
Oops, I posted the info for this on the VTech problem below sorry.
To change the message, first make sure your phone has the correct date, time, year, am or pm, etc.
Now, to Record Greeting - if you don't record your own greeting, a pre-recorded greeting message is used.
So, try this:
1. (Menu) press
2 (Go to Answering Device" with up/down arrow, press OK
3 (Go to "Record Greeting" with up/down arrow, press OK
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the
5 To stop recording, press (OK)
6 (OFF)
Hope this helps.
Mar 30, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Short record time on my answering machine
The only thing I can think of is that there is a switch which determines recording time, there was on mine and then there was the VOX option which only recorded as long as they were speaking and cut them off if they didn't talk quickly. You might check and see if somehow they got turned on.
Jul 15, 2009 | Answering Machines
Personal message not going out
Generic message mean the origional memo from manufacture? or the record message from caller far end? Try to power off and on again, record your personal anoucement one more time.
Jan 20, 2009 | GE 29875GE Digital Answering Machine
Beotalk 1200answering machine
Try joining the company's website. You should then be able to download the manual.
Feb 25, 2008 | Bang and Olufsen Beotalk 1200 Digital...
GE Digital Messaging System Model # 29875GE1-B
If I am away from my machine and want to call my answering machine and hear the messages what do I do. Lost my manual.
Jan 07, 2008 | GE 29878GE1 Digital Answering Machine
Problem with GE Digital Messenging System #29871
I called the support number in the manual. They said to try a power off and power on sequence. Unplug phone line and then power, wait 10 minutes, and replug phone then power. If that doesn't work they said it is defective. My machine still didn't work so I am replacing it.
Nov 23, 2007 | GE 29871GE3 Digital Answering Machine
Bang and olufsen BEOTALK 1200
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Aug 28, 2007 | Bang and Olufsen Beotalk 1200 Digital...
AT&T 1738 Digital Answering Machine Logo
256 people viewed this question
Top AT&T Answering Machines Experts
Are you an AT&T Answering Machine Expert? Answer questions, earn points and help others
