Question about Toshiba Satellite L305-S5939 (PSLB8U-0JC045) PC Notebook
When i put it on it start to open the windows but when its all about to open the power is automatically shut off and auto back on again
It goes on and off again and again
    Top Expert:
  • Toshiba Master
  • 23,159 Answers
Try running CHKDSK/F in safe mode to check for hdd errors.
Posted on Mar 27, 2014
I have a 2006 mazda 6 automatic 6 speed. The passenger window continues to roll down by itself while the car is in transit as well as shut down. I travel a lot. Here it goes again
You could try disconnecting the switch wires for the passenger side when the window is up. If the window stays put then simply buy a new switch or live without an opening passenger window.
Aug 21, 2014 | Cars & Trucks
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Auto trans car chokes down and engine shuts off when in gear
the torque convertor is locking up,There is a plastic wire harness on top the transmission,Unplug it from the transmission and your troubles will cease,
If you want it repaired and transmission shop can do it,or you can drive it for ever unplugged
Jan 26, 2010 | 1993 Oldsmobile Cutlass Ciera
Turn camera on, lens goes in and out then camera shuts off
You may try resetting the Camera to the original factory settings.
If the issue persists then service will be required.
Aug 27, 2009 | Panasonic Lumix® DMC-FS3 Digital Camera
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Toshiba Satellite L305-S5939 (PSLB8U-0JC045) PC Notebook Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
