Question about Peavey CS 1400 Amplifier
I wanna know the value of transistor used in peavey cs 1400.
The transistor due to short circuit
  • 88 Answers
You will need the schematic diagram
Posted on Nov 12, 2014
2 Suggested Answers
  • 32 Answers
SOURCE: how work peavey cs 1400? is good
I just added a CS2000 to my rig and it is powering a pair of Peavy SP2s and a pair of SP118 with no problems at all and it sounds great. The CS stands for Commercial Series and is the workhorse of Peavey. I highly recommend them.
Posted on Jan 26, 2010
What is the speaker load impedence of the speakers
Looks like you can use minimum 2 ohms, max 16 ohms
LFC Impedance Sensing
CS Series amplifiers feature innovative circuitry for safe operation into any load. When an amplifier senses a load that
overstresses the output stage, the Load Fault Correction circuit adjusts the channel gain to a safe level. Extreme load
fault under high power levels will cause the signal to be muted for the associated channel. This method of outputstage
protection is far more effective than the standard limiting found on conventional power amplifiers. The LFC
circuit is sonically transparent in normal use and unobtrusive when activated.
Jun 20, 2014 | Peavey CS 1400 Amplifier
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
HOT transistor TT 2222burn after second replace. TV Samsung Model CS-21Z45MJ
Hello
Before replacing an other one, replace the freewheeling capacitor, the capcitor fitted between the collector of the 2222 and earth; usually of a value of 3500pf 2000VDC, some times this value may differ from set to set. If this capacitor has opened of developed in value, the result will be the failure of the horizontal output transistor, at switch ON itself. The second reason is the short in horizontal yoke windings. Even one winding get shorted, it will cause to a heavy load flyback transormer which in turn to 2222 failure. The last reason for this fault is defective Line Output Transformer itsef. Check these three.
Before proceeding, desolder out the horizontal output transistor 2222 fro circuit, and measure the frequency at the collector point of horizontal driver transistor. It should be around 15625HZ [may differ a little], with no signal. If this frequency is found higher than normal, The main IC jungle should be suspected.
Anyway, go forward after checking this frequency. OK.
Jun 10, 2011 | Televison & Video
How work peavey cs 1400? is good
Aug 21, 2009 | Peavey CS 1400 Amplifier
How work this peavey? is good
The CS series from Peavey is their workhorses. They are very good and reliable. I have been using variation of the series now for nearly 20 years with no problems. CS stands for Commercial Series meaning that it is intended for commercial use.
Peavey TNT 160 has no response from both inputs, only preamp in
In my experience fuses rarely blow due to age! I suspect that whatever the guy said the problem was it was really a faulty transistors or IC in the power amp board.
You can check transistors with an Ohm meter in circuit to some extent. (the ones with a scale and needle are best for this) Look for a short between the terminals of each power transistor on the heat sink first. If any transistor sends the meter full across (both ways) you have found the fault.
Apr 24, 2009 | Peavey VTB1 1-Channel Amplifier
Channel A keeps switching on then off again when
Over heating from dust. (thermal blanket) Remove top and blow out. Also, observe proper output impedance matching.
Paul
Apr 05, 2009 | Peavey CS 1400 Amplifier
I NEED TO HOOK UP MY CS 4000 AMPS
If you are trying to use 3 amps to drive a single cabinet, it can not be done. Bridging amplifiers requires a specific circuit design for that application. There is no way to hook up multiple amps to a single speaker.
Dan
Mar 04, 2009 | Peavey CS 1400 Amplifier
Peavey amp
You could also use speakers rated less than 400 RMS provided you dont crank the volume knobs all the way up.
I think the CS400 is 200 Watts RMS per channel into 8 ohms
400 watts bridged
Here's the manual. You'll need acrobat to open it.
http://www.peavey.com/assets/literature/manuals/80300990.pdf
Dec 05, 2008 | Peavey CS 1400 Amplifier
Peavey cs400 amp
Hi...
That 28V RMS means how many RMS volts max comes out of the speaker terminals.
As long as your speakers can handle a couple hundred watts , youre fine.
77 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
shaqsatin
Level 1 Expert
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
