Question about Mercury Computers & Internet
Open in safe mode when am start my computer blue screen error and i can solve problem using by safe mode but am unable to open in safemode please give the sollution am using mercury motherboard and op
Am anable to open in safe mode
tom19511
  • 1601 Answers
SOURCE: unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Posted on Dec 19, 2007
map9966
  • 2351 Answers
SOURCE: Gigabyte GA-MA790FX-DQ6 installation problems
Hi speedfreak44, during the installation of windows one of the drivers did not install correctly & windows registry is messed up.
The blue screen is a typical response from windows. Even though you're windows installed SP2, there are another 89+ updates for SP2. (A reinstall with-out a format is not advised).
Suggest you enter you're bios & disable ACPI. This one I know for sure will show up in windows device manager as a PCI device with no name. Try again to boot windows. If it still fails to enter in standard mode than a complete re-install will be required including a format. Personally I do not use windows XP pro/home w/SP2 CD to perform the format, (After receiving a blue screen).
I have found it is 98% better to use the software tools, downloaded from the Mfg's web site for you're hard drive. Use the bootable software (On a floppy or CD), to format you're hard drive. Most Mfg's hard drive software will allow you to change the cluster size up. Windows standard uses a 4kb cluster size & you loose far more hard drive space. With a 16kb you loose only the file allocation or FAT, which is normal.
Than using the Win XP CD/SP2 install windows, clean.
(No need to format).
When finished installing windows, load the Gigabyte driver CD & install the chipset & other CD drivers. Turn on windows firewall & update windows SP2. (ASAP), (Save SP3 update for later).
It is in the updates of windows to iron out software & hardware driver updates. Do not install you're antivirus software until windows has finished updating its self & you install any hardware updates also through windows update. (Continue to leave the ACPI disabled in bios until updating is complete).
You can enable ACPI, antivirus software & printer software all.
You will find some needed software will install during windows update. Like; Quad Core processor update. With either home edition or pro it is advised to install .Net framework updates 1 at a time & only restart when prompted by windows. Other wise click the refresh button & continue windows updating. (You can save the .Net framework updates for last if you wish). You're video card may need .Net framework 2.0 or better for installation.
I am hell bent on installing windows once & correctly the first time. I understand you want to get this baby up & running but take the time & run the hard drive tools/utilities. (It's worth it)!
Good Luck speedfreak44!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Please let me know if this got you're system running without the blue screens?
One last item. It's also worth checking the dates on the Gigabyte CD to Gigabyte's web site before installing other drivers. Including the chipset drivers. You want to install the newest drivers the first time around. Here is the link to you're Gigabyte GA-MA790FX-DQ6 motherboard main web site.
(Click on the link).
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=2690
Mike
Posted on May 27, 2008
pankaj_dic
  • 1250 Answers
SOURCE: problem of blue screen error messege
you have installed the inf setup or not, install all the updated drivers of your motherboad
Posted on Oct 03, 2008
  • 59 Answers
SOURCE: Windows won't start
you may want to try to re-install window but use whats called a non desturctive install, when you put the disk in and asks if you want to format the drive or leave the file system intact ......leave the file system intact this should keep all you data however you will need to re-install any programs you have put on the computer other than a standard install of windows......
It would appear that the boot loader (mbr) has become corrupted as you said you tried all the options in the safe boot menu............let me know how you get on
Posted on Oct 11, 2008
  • 145 Answers
SOURCE: Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Posted on Oct 16, 2009
Code error 0xc0000185
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Jul 03, 2013 | Sony VAIO Computers & Internet
My computer screen turns blue and restarts window vista
Hi jjlishus,
I see you mentioned that you are having issues with you computer going into a blue screen then it restarts.
You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.
From there-on see if the issue will still happen or no
Getting into Safemode:
restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.
If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.
to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.
once in the command prompt
Type CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.
if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.
I hope that this will help,
mvincentc
Jun 07, 2012 | Acer Brand 14.1 WXGA Matte Laptop...
Blue screen, black screen of death.... numerous times... can only start in Safemode. Can I do a data transfer while in safemode without crashing?
yes you can transfer the data in safe mode and also you can do a system restore for the last good checkpoint in safe mode which will resolve your issue from blue screen also
Oct 05, 2010 | Computers & Internet
Acer Aspire 5535-5050 only starts in "safe mode"
when you get to safe mode try to do a system restore to a date that the computer worked............on xp it will give you a screen to enter safemode with yes or no options ........choose no to go diorectly to system restore...............if not xp look for system restore in the system tools folder on start menu or in control panel............the screen saver error is most likely because you are in safe mode.
Jul 19, 2010 | Acer Aspire 5535-5050 Notebook
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
Feb 15, 2010 | Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Blue screen.
It might be a software issue but it also be a hardware issue..especially memory error.
You need to reinstall your OS if can't restore using safemode & system restore. Or can't open windows anymore.
If you have another space harddisk install OS there: install antivirus & antispyware. copy files your files & format the drive. SOLVE
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
Problem with windows. It won't boot up
this only problem with windows or virus....
you can use recovery to solve this problem..nothing else...check and it will work fine
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Unlocking laptop from safemode.
Boot the PC with tapping F8 Key during start. It will give you option for selection of Safe mode.
Let me know what the screen shows in both mode. Any error message will help out to fix the problem
Oct 05, 2008 | Acer Computers & Internet
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
