Question about Port Designs Computers & Internet
USB ports keeps blowing even blown USB printer port
pastorm
  • 98 Answers
SOURCE: problem connecting and printing my lx-300 matrix printer
You need to get a paralell to USB cable, like the one on the following link: http://catalog.belkin.com/IWCatProductPage.process?Product_Id=20651
Posted on Sep 08, 2007
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
SOURCE: can't connect to usb port
Hi all! I had the exact same problem - the remote recognized the USB connection but my computer (MacBook with Leopard) / Logitech software did not.  I took the advice of  bfuzcsvxvgk  and it worked like a charm.  I wasn't sure what the "Home" folder that he or she referred was, so instead I entered "Logitech" into the Spotlight finder and the Logitech folder came up.  There was only one file (usblancognac.cmd) in the folder and I deleted it. After that I reopened the Harmony Remote software and it opened! THANK YOU THANK YOU THANK YOU!  Hope this helps if you are having problems!
Posted on Jan 16, 2009
  • 31 Answers
SOURCE: Power port/ cigarette lighter keeps blowing fuses
the cig lighter might be shorting out and cauding the other problem. sell the car and buy a toyota.
Posted on Apr 29, 2009
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
One day able to attach external drive/disk via USB port - next day unable to reconnect - Computer properties did NOT show EXTERNAL drive at any PORT
Whenever you use coaxial or phone lines make sure to use a surge protector power bar. They have a thermistor in them to blow up and protect your equipment. I'd say you have blown a diode or ic that supplies power and converts data from the usbs. It may just be one of your voltage wires from your power supply.
Nov 18, 2013 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Printer only works on one USB port
You can swap thye ports areound on Vista, but Xp is more difficult. What happens is the USB is converted to an LPT port like lpt1 or 2. This remains in the device manager list because it is usally a fairly permanent object. USB printers are rarely totally USB, like other items. So windows fails to recognise the printer on other ports or, it will require a new installation for that port. With Vista you can go into Device manager and reassign a USB port to a printer port. XP is another ball game you might not want to play in.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 18, 2009 | HP Deskjet 5740 InkJet Printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Re: Canon Pixma MP530-- When I go to print the message reads " One of the USB devises attached to this computer has malfunctioned, and Windows does not recognize it. For assistance in solving this...
sounds like the usb port on the printer has popped . If u delete /uninstall the driver .Then reconnect the printer does it say "new hardware found" if not the port is blown on the printer
Nov 26, 2008 | Canon Office Equipment & Supplies
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
PRINTER PORT FOR HP A6230N
I am sure it came with USB ports, most design nowadays expect you to buy USB enabled printers.
So I advise you buy a USB - CENTRONICS or USB - SERIAL cable depending on the type of printer you have.
You will connect the USB end to your computer and the other end to your printer.
If your printer is fairly recent, you might even have a USB port on it, so check.
HTH.
Dec 05, 2007 | HP PAVILION A6230N DESKTOP PC
Computers & Internet Logo
65 people viewed this question
Top Port Designs Computers & Internet Experts
Martin Murray
Prashant M
Prashant M
Jax Planet
Jax Planet
Are you a Port Designs Computer and Internet Expert? Answer questions, earn points and help others
