Question about HP LP2065 Monitor
Screen sethi, i am using HP LP2065 LCD with my computer. Now the problem is that color setting of LCD is not good and hence no clear picture and video.Please suggest me what i should do. thanks
Colour and Visulation problem.
  • 128 Answers
Try in menu auto adjustment and factory reset......
you can also play with frequency a little and color setup , clock and clock phase in Image control menu, play with it and you will see result... then save it...
Posted on Mar 27, 2014
Lp2065
if screen black but green light on then is inverter was bad.
if screen black n green light off or amber then check then monitor defective.
Try with different monitor and result the same problem, either the monitor or the video connection.
Apr 01, 2014 | HP LP2065 Monitor
HP LP2065 MONITOR goes to sleep
Hi There The Monitor setting you set through the computer, may you select the sleep mode or hibernate. Chang the mode and fix the problem.
Thanks http://pacificbits.ucoz.com/
May 08, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Lcd vertical lines
Hook a spare monitor to the computer, if okay! the problem is with the HP monitor "LCD panel defective" not cost effective to repair. But if symptoms are the same for both, the video graphics card on the computer is defective, sub a video cord from the computer to the monitor if possible to cover all angles.
Mar 13, 2012 | HP LP2065 Monitor
Laptop hdmi to dvi monitor
Yes that will work fine
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 28, 2011 | HP LP2065 Monitor
I have an HP LP2065 monitor that I am trying to hook up to a laptop. When the monitor is hooked up it will flash the image on the screen and then go out. When you push the input button on the front of...
The monitor is faulty, this is confirmed when you connected to several laptops.
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp for the back lighting. Have a close look at the monitor at a sharp angle, if you see a faint Windows image then it is definitely a back light fault.
For parts, check out these WEB sites.
LCD screens and Inverters
www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
Mar 05, 2011 | HP LP2065 Monitor
I have a HP LP2065 monitor, and it is currently displaying lines (red, blue and green) vertically on the screen, how do I resolve this problem?
Hello
OK, firstly, this problem can be due to a couple of factors. I will explain it in as much detail as possible.
Internal cracked LCD:
This is the most probable cause for these lines on the screen. Unfortunately this is not something which can be fixed without replacing the whole screen.
Damaged DVI cable:
A faulty DVI connection between the computer and the LCD screen will also cause this symptoms.
Faulty Graphics Adapter:
Lastly, this can be due to a faulty graphics adapter. If you use the on-board adapter, i would suggest that you first test the graphics adapter with another screen. Also, take out the graphics adapter and place it back in, just to make sure that there is not bad connection.
With all of the above explained, i will suggest that you start by testing the system with another screen. If the problem persists, check the connection with another cable.
If all else fails, have a look at the graphics adapter you are using.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 12, 2010 | HP LP2065 Monitor
When looking through the display screen the picture has a pink tinge. When reviewing the pictures they're definately pink in colour, especially the blues.
Try taking pictures and download them to a computer. Check the colors and evaluate the quality compared to what you have seen in the LCD display.
If the pictures are good and the colors seem to appear good on the computer, then some thing is either not adjusted correctly for the LCD or you may have a menu setting which is incorrect. Check all setting in the menus.
Test the camera again, and see what the colors look like in the LCD display.
If both the LCD display and the pictures on the computer are the same, then some problem exists in the camera, and may need fixing, or sell on a site such as Ebay for parts or repair as is.
Oct 25, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
HP LP2065 AS 2ND MONITOR
Make sure in the control panel under power options you change the settings so the screen doesn't go into sleep mode and make sure the display doesn't turn of. Do this by changing the times to never.
Feb 08, 2009 | HP Computers & Internet
Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
Oct 07, 2008 | HP LP2065 Monitor
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
HP LP2065 Monitor Logo
59 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
