Question about Xerox WorkCentre 7120/P Printer
How can i resolve error 166-365 on my xerox printer
The printer is saying restart the machine
  • 2072 Answers
SOURCE: lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Posted on Dec 31, 2007
  • 2072 Answers
SOURCE: Xerox phaser 6180n
Sounds like the memory stick is loose.
If you just received it, that machine has a one year warranty on it.
Call and Xerox will send someone out, or else they will replace it.
Your going to love that printer. WOW what print quality it has.
But your problem most likely was due to shipping and something coming lose.
Call 1-800-835-6100, follow the prompts, they will help make it right.
Posted on Jul 12, 2008
  • 10 Answers
SOURCE: Xerox system error 09,035,43:46300.
This is from the service manual
Harry
9,035.43 through 9,038 (8500/8550/8560 only):
Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Troubleshooting Procedure for Ink Loader
Step Questions and Actions Yes No
Is the ink Genuine Xerox? Are they the
correct sticks for the model?
Go to Step 2. 1. Advise customer.
2. Replace the Ink
with Xerox Ink.
3. Run Clear ISC
Fault
test to clear
the error. The
Clear ISC Fault is
located in the
Internal
Diagnostics
Function menu.
2 Manually verify that the ink stick is able
to advance in the ink loader chute.
Check for broken or wrong type ink
sticks.
Go to Step 3. 1. Remove any
blockage and/or
replace the ink
stick.
2. Replace the Ink
Loader.
3. Run Clear ISC
Fault
test to clear
the error
Posted on Aug 25, 2010
Joed911
  • 4338 Answers
SOURCE: I have a Xerox Phaser
042-372 K Mode Sol Error Restart Printer Error 042-372 Restart Printer Each color has it's own solenoid. the K solenoid is the one for the black ink. It may be that toner has clogged the sensor on the inside right wall of the printer. Sensor hole is a small opening and K is the first hole. Clean it with a cotton swab and alcohol. clean any loose toner also. If this does not take care of it. The sensor board or the solenoid itself needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 19, 2011
damneddle
  • 1607 Answers
SOURCE: Have Xerox Phaser Printer Error 09,008.43:100277.
Try using "PhaserSmart" to automatically diagnose the problem of your printer. You just need to input the IP address while your printer is turned ON.
Phaser SMART
Posted on Sep 18, 2011
Error Code 9-456
This error code means the life of the black developer is at its end. It is probably time to replace all four developers and the only reset is replacing the engine control board.
The costs will come around 1000usd I recommend you buy a new one.
Jun 18, 2008 | Xerox Phaser 7750DN Laser Printer
Solutions to 16-593.00 in xerox workstation 5755
That error signifies that the machine is set to DHCP but cannot resolve an IP address from your network. Normally you would assign a static IP address on your printer. I would recommend setting a static IP address with subnet and Gateway that correspond to your network. That should resolve this error.
Jan 05, 2016 | Xerox Office Equipment & Supplies
Docucolor 252 fault code 047-310 How do you fix this?
This error code indicates that the Xerox is not communicating with the finisher. The recommended method to resolve this is to power off the Xerox, wait 3 minutes after power is off, unplug the machine from the wall, wait 1 more minute and plug in and restart. If that does not help, it will require a call to the service number: 800-821-2797
Jun 08, 2009 | Xerox DocuColor 12 Color Copier
Open heat error
One of 2 things is happening, Either the Heating element is going bad, or more likely the thermistor that monitors the temperature of the fuser is intermittent. You will most likely need to replace the fuser to resolve the issue. That machine has a one year on site warranty. If its less than a year old Xerox will fix it for you free of charge.
Oct 03, 2008 | Xerox Phaser 4500 Printer
Xerox phaser 6180n
Jul 11, 2008 | Xerox Phaser 6180N Laser Printer
Lsu error
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Error message F952
Xerox has some fantastic support information on their site. I can't say enough about how much detail they provide. One of their documents for your printer is, "Solutions for How To Resolve an F952 Error Message." The document can be found at the following location: http://www.support.xerox.com/go/go.asp?ksessID={88EEB946-3A34-4AF9-801B-0756917C085D}&Xlang=en_US&Xcntry=USA&prodID=M940&objID=6581 NOTE: After clicking the link above, you'll need to click the link, "Continue to the Support page" at the bottom of the page. If their information doesn't resolve the issue, please let us know.
Aug 22, 2007 | Xerox WorkCentre M940 InkJet Printer
Xerox WorkCentre 7120/P Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
