Question about Toshiba Satellite L305-S5939 (PSLB8U-0JC045) PC Notebook
Its written to start wndows normally but still doesnt start
Always failed to start
    New Friend:
    Problem Solver:
  • 7 Answers
Get into safe mode at the beginning select either F8 or F10.
Run a diagnostics check,defragment all the drives ..basically clean the computer. Delete whatever u previously installed .through the control panel...add or remove programs...
Use Ccleaner and clean your computer through this software and it should b fine. Let me know if this would help.
Posted on Mar 28, 2014
    President:
  • 252 Answers
If you are using Windows 7 then here is the solution
Posted on Mar 27, 2014
  • 128 Answers
Try to start windows in safe mode, then check for problems, run hdd scan and try to restart in normal mode
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
I have an Asus M51A with built in camera when i try to install the drivers for it it returns an error that there is no camera found, it doesnt show in device manage i also have an error for the mobile...
If you do a cold start, unplug AC from remove battery, hold on/off button for a few seconds, replace battery, plug into AC, start normally. Your windows vista OS should ID your webcam and search fro the driver and other devices. Run windows update for drivers and updates. If that fails look for the drivers here: http://www.asus.com/Notebooks/Multimedia_Entertainment/M51A/#download
Nov 09, 2012 | ASUS M51A-A1 PC Notebook
Lgq9030pqo start dryer ,everything normal gas kicks on starts heating., heats for a couple of mins then cuts out doesnt come on again drum keeps on going everything else is normal
Typically - when this happens - the gas valve solenoid is failed, and needs replacement.
The flame sensor (thermocouple) may also be the culprit if it is failed - it will not tell the valve there is a flame present.
Check those out.
Thanks!
Aug 23, 2011 | Dryers
Starts fine in the morning after 20 minutes of driving i turn off the car try to start and car runs rough or doesnt start 1989 olds cutlass ciera
i would check the fuel injectors early style injectors always do what ur explaining when they fail on a heat soak engine
Jul 09, 2011 | 1989 Oldsmobile Cutlass Ciera
2000 vw beetle starts fine when engine is cold, sometimes won't start when engine is warm my mechanic doesn't know what trouble is because it always starts for him. the problem is erratic.
spray quick start when it doesnt start, If it starts then replace the main relay and fuel pump relay. If it still has this issue then replace the fuel pump. The only other option is to wait till it fails completely and only then will a shop be able to properly diagnose this. If you take it in and it doesnt act up for the mechanic then its going to cost you and they won't be able to fis it. .If it doesnt start when you spray quick start then the problem is ignition related and it could be the main relay, or ignition module or crank sensor.
Jun 14, 2010 | 2000 Volkswagen Beetle
1991 geo storm stalling at idle
maybe try replaceing the ingnition modual. that part can do a lot of weird things to these cars. its located inside the distributor cap, really easy to do. about $40 and 10 mins or less. sometimes as they start to fail they do odd things sometimes but not always
Mar 13, 2009 | 1991 Geo Storm
Window Media Player & winap Doesn't play in nomal speed
In WMP press ctrl shift n and it will play at normal speed
Jan 04, 2009 | Computers & Internet
Printer wont work with windows
Need more information. What operating system? what model of printer
Feb 20, 2008 | Lexmark All-in-One Printer with PictBridge
Toshiba Satellite L305-S5939 (PSLB8U-0JC045) PC Notebook Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
