Question about Coaster 600333 Walter La-Z-Boy Style Rocker Recliner in Brown Bonded Leather
Need to order a pawl and ratchet assembly
Who can I order from
The ratchet on craftsman microtork torque wrench 44593 does not work
The ratchet pawls have seized and a ratchet rebuild kit is needed.
Jul 20, 2014 | Craftsman Microtork Torque Wrenches -...
Spin cycle doesn't work
I don't know if this applies AT ALL, but if it does, then it would be an easy fix. If your washer isn't like mine was, then just ignore the following:
Start by popping the cap on the spindle inside the drum, it just has a plastic cap that pops off. With that cap off you can try turning the little doodad inside one way and then the other, and it should "ratchet," catching and making the spindle turn when you turn it one way, but freely spinning the other way. IF it freely spins BOTH ways, the pawl dogs are worn. This is what was wrong with mine, and the pawl dogs are cheap and easy to replace. To get to the pawl dogs themselves you would just need to loosen one bolt head under that cap, and lift the assembly out, and then the pawl dogs are on that assembly.
Mar 06, 2014 | Kenmore 24032\24036 Top Load Washer
I ned new starter pawl ratchet for 125l
HandymanJ has the perfect solution. I did it and it worked great. Thanks.
Sep 24, 2012 | Husqvarna 531004153 Starter Pawl/Ratchet
Liftgate won't open automatically
To open the lift gate manually, use the door unlock switch located on the drivers door. This should unlock the lift gate as well. Go to the lift gate and lift the handle to open the rear gate.
Your power lift gate is computer controlled. Sometimes there will be a faulty input sensor or part that will show the incorrect data to the computer, therefore the computer will not go through its normal functions.
In most cases its the problem of lift gate latch assembly.
To get it tested and confirmed there is a troubleshoot guide provided by the service center. To perform this troubleshooting guide you will require a scan tool to diagnose the exact problem.
the troubleshooting procedure is as follows:---
Please use the following information below when diagnosing an inoperative lift gate. Disconnect the connector at the lift gate latch assembly. With the lift gate latch connector disconnected, the 3 signals for the ratchet, pawl, and the sector should be inactive on the scan tool.
Install a 3A fused jumper wire between each signal circuit terminal (for the pawl, sector, and ratchet) and the ground circuit terminal 2. Monitor the scan tool as each individual circuit is jumped to ground, the scan tool should read "active".
If either tests above fails, check the wiring for the signal circuits, low reference circuit, or try a power lift gate control module from a known good vehicle. If both tests above pass, monitor the internal switch inputs in the lift gate latch assembly for proper operation.
3. A) with the lift gate in the open position, the ratchet and the pawl should read "active" and the sector should read "inactive"
B) With the lift gate in the secondary latched position, the pawl should read "Inactive" and the ratchet and sector should read "active"
C) With the lift gate fully closed, the pawl, ratchet, and the sector should all read "inactive".
4.If one of the internal lift gate latch assembly switch inputs are not reading correctly in one of the positions above and the vehicles passes test 1 and 2 above. Replace the lift gate latch assembly.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
This should help you.Thanks.Helpmech.
Dec 04, 2010 | 2006 Cadillac SRX
Troy-Bilt shredder model 204 tire problem.
Put a ratchet strap around the tire and tighten it up until you seat the beads enough to get some air in it and then you can fill it back up from there. hope this helps you
Oct 26, 2009 | Troy Bilt Walk Behind...
How to remove and replace rear wheel tire on my mtd self propelled lawn mower model #126-478n134 part #634-0020 tire sized 8 inches.
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Sep 30, 2009 | Mtd 22" Yard Machine Push Mower
My wifes car seems to get stuck once you put it in gear. she has a ford fiesta P reg. the only way to get it out off gear is to stall it or switch off the engine, once this has happened you need to get...
Hi Stu!
The problems lies with clutch operation, Not having much to do with Fiesta's but sorting similar problems classic Ford vehicles.
I take it the clutch is operated Via a cable? on recent Fords they use a plastic Ratchet and Pawl system which automatically adjusts when cable stretches.
This may have reached its maximum so a replacement is required, also would be adviseable to change the cable too.
Have you a decent spares stockist's local? Halfords can help but you'll need to take out a Mortgage for their parts.
So Shopping list, 1. Auto adjuster (Ratchet/Pawl) 2. Clutch Cable, 3 Lube for cable and shaft on pedal assembly and 4 Haynes Manual.
Good Luck Stu!
You can do this I know you can.
Paul 'W'
Onyer~EDson(:0)~[><
Jan 13, 2009 | 1999 Ford Escort
How to install a clutch ratchet for ford escort van
Hi
If its the self adjusting pawl and ratchet on the pedal you're on about then its a nightmare, and your life will be so much easier if you actually remove the pedal assembly, fit the pawl and ratchet to it, and then refit the pedal assembly.
I think there are about 4 or 5 bolts if I'm not mistaken, a couple or three inside the car and a couple or three under the bonnet on the bulk head.
Once you've got the pedals off all will become clear.
Very best regards
Geordie
Jun 19, 2008 | 1996 Ford Escort 4 Door
Coaster 600333 Walter La-Z-Boy Style Rocker Recliner in Brown Bonded Leather Logo
162 people viewed this question
Top Coaster Furniture Experts
John mullen
ray gallant
Are you a Coaster Furniture Expert? Answer questions, earn points and help others
