Question about Tally MT661 Printer
Suddenly printer and unix not communicating MT661
Print files stay in spooler and first one prints if we shut system down but none of the others print
3 Suggested Answers
  • 169 Answers
SOURCE: data overrun
I would hazard a guess that the printer is connected via the serial interface.....
If this is the case you either have a problem with you serial interface settings or the serial cable pin configuration does not match the printers serial interface pin configuration..
I would recommend printing a MENU print on the MT661 and check the serial interface settings these NEED TO MATCH THE HOST SYSTEM
To print a menu print.
  • Put the printer OFFLINE
  • Press MODE
  • Press the DOWN ARROW to HELP
  • Press ENTER
A menu print will be printed look for things like Protocol, Baud Rate, Data Bits, Stop Bits etc
These need to be set to match the host computer system.
Posted on Oct 02, 2009
  • 169 Answers
SOURCE: tally mt661 printer gives data overrun error after
The Data Overrun error is normaly associated with the incorrect serial interface settings on the pritner or the serial cable may have the wrong pin configuration or be damaged in someway.
I would recomend checking the serail interface settings including the follwoing settings; Parity, Protocol, start bits and stop bits
Posted on Feb 19, 2010
Prints the same picture nonstop, I have to shut the printer down to stop it. Now the printer does not react at all, almost like its not connected....??
Remove the power plug before stopping spooler to erase printers memory. and plug back in power when spooler service restarted.
control panel in windows operating system , services, print spooler, Stop the print spooler and restart spooler.
Mar 09, 2016 | Office Equipment & Supplies
Tip
Printer Spoiler problem
<p><br />If the Print Spooler service fails when printing or when Windows starts or it can not be restarted, the usual reason is that one or more printer drivers is defective. The simplest way to resolve this is to remove all the drivers and reinstall them again.<br /> <p><br />If the Print Spooler service is not running, the Printers and Faxes folder will be empty and you can not use it to remove (or add) printers or printer drivers. <br /> <p><br /><b>Resolution:</b><br /> <p> <br /> <p><b>Windows XP:</b><br /> <br /> <p>If the Print Spooler service is operational:<br /> <p>1.<span> </span><span>Open the <b>Printers and Faxes</b> folder, Start-&gt;Printers and Faxes.</span><br /> <p>2.<span> </span><span>Delete all of the <span>printers</span></span> <br /> <p>3.<span> </span><span>Click <b>File</b>, Server Properties</span> <br /> <p>4.<span> </span><span>Select the <b>Drivers</b> tab</span> <br /> <p>5.<span> </span><span>For each entry:</span> <br /> <p>a.<span> </span><span>Select the entry</span> <br /> <p>b.<span> </span><span>Click Remove</span> <br /> <p>If the Print Spooler service is not operational:<br /> <p>6.<span> </span><span>Open regedit Start-&gt;Run and type regedit.</span> <br /> <p>7.<span> </span><span>navigate to <b>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers</b></span> <span>Under this key, there will be the keys Version-2 and Version-3 (one or the other of these may be absent - not a problem) the sub-keys under these contain the printer driver configuration information. Delete all the sub-keys inside Version-2 and Version-3, but <i>not</i> these keys themselves</span><br /> <p>8.<span> </span><span>Open a Command Prompt window</span> <br /> <p>9.<span> </span><span>Type the commands<br /> <span><b>net stop spooler</b></span><i><br /> </i><span><b>net start spooler</b></span></span> <br /> <p>10.<span> </span><span>Open Windows Explorer</span> <br /> <p>11.<span> </span><span>Navigate to <b>%systemroot%\system32\spool\printers\</b> and delete any files there. By default, this is where the <span>print spooler</span> stores print files.</span> <br /> <p>12.<span> </span><span>Navigate to <b>%systemroot%\system32\spool\drivers\w32x86</b>. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem) delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside w32x86, there may be other folders with names starting with "hewlett_packard", "hphp" (ex. for HP printers) or something else; delete these folders also</span><br /> <p><span>13. </span><span>Restart the <span>print spooler</span> (see steps 8 and 9 above)</span><span> </span><br /> <p><b>Windows 7:</b><br /> <ol> <li> Go to <b>services.msc</b> -&gt; stop the printer spooler service. <li> Get into windows /system32/spool. <li> Find folder named printer and delete the contents of it. <li> Restart the printer spooler service, check for printing. <li> Restart the computer and check it again.</li></ol> <p><span> </span>OR<br /> <p>cmd<span> </span>-- &gt; net stop spooler<br /> <p>del /q /f /s "%systemroot%\System32\Spool\PRINTERS \*.*"<br /> <p>net start spooler
on Mar 10, 2011 | Office Equipment & Supplies
Will only print on quick print not on normal or photo
The problem could be due to your computer's Print Spooler or a possible firewall issue blocking the required processes for printing. Try the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
However, if this is a firewall issue, please refer to this article from the Lexmark website on Processes (Executables) Utilized by Inkjet Products; A Brief Description of Their Function. Follow the steps in the article on how to allow the required process for your firewall.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 15, 2011 | Lexmark X6570 InkJet Printer
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
A print job queue is preventing other print jobs from printing
a print job in the print queue is preventing other print jobs from fixed printing
Dec 30, 2010 | Costar DYMO DiscPainter Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
Data overrun
  • Press MODE
  • Press ENTER
Jul 07, 2009 | Tally T2250 Matrix Printer
A file won't Delete
You will have to manually clear your print queue. Here's how:
Start > Run > In the box type: services.msc
Scroll down the list and find LEXBCE server, Right-click on it and choose RESTART
Next, scroll down to PRINT SPOOLER, Right-click on it and choose RESTART
Your print queue will then clear out and the communication between your Dell (rebranded Lexmark) will be reestablished with your computer. Good luck!!!
Sep 19, 2008 | Dell 924 All-in-One InkJet Printer
Printer spooler freezes
you can try restarting the printer spooler by
pressing start -> run -> type in Services.msc
on the services list find print spooler and right click - restart.
That should solve it without a restart.
Jun 25, 2008 | Lexmark Z645 InkJet Photo Printer
26 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
