Question about Samsung Washing Machines
Unlock door whilst machine is in cycle
Unlock door while machine is in cycle
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Washing machine door not opening
If the unit has not drained fully the door will not open, check the filter for foreign objects and then put the machine on spin cycle, check the door after this. Worst case scenario is the the door handle was pulled too hard whilst the door was still locked and the catch has broken. Post if more assistance reqd
Feb 20, 2013 | Bosch Classixx WVF 2402 Front Load...
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Door wont unlock once a wash cycle has begun
    that is correct ,. pump water out then the door will open.
    May 20, 2011 | Kenmore Elite 45986 Front Load Washer
    I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
    Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
    Mar 08, 2011 | LG WM-2277HW Front Load Washer
    Unusual display on panel (padlock) machine can't be programmed door is not locked however
    i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
    May 31, 2009 | Electrolux EW1000i Front Load Washer
    Washing Machines Logo
    12 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
