Question about Dehumidifiers
4 days notice without any reasons.
Sins I moved in, she come to visit regulary. I stop that, then she is constant on the phone. On the premises I rent, there is a flat that she rent out. every weekend there is violents and the people using drugs. we phone the police and now she is very cross with us. She gave us notice yesterday to be out on the end of the month. I have % children and really there must be a law that protect us from people like this. We are not behind with our rent.
    Top Expert:
  • 21,522 Answers
Check your contract and then your country laws.
Posted on Mar 27, 2014
Pause light is constantly flashing
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Dec 13, 2014 | Dehumidifiers
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
Machine runs, but no water is coming out into the bucket
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
Jun 02, 2011 | LG LHD459EL Dehumidifier
P1 constantly goes on throughout the day. I do not know if I have the setting right or if the drain hose is connected properly.
First, the drain hose should not be longer than 5 feet and should be draining downward, with no kings or bends in the hose, The dehumidifier does not have a pump. It relies on gravity to drain the water.
As far as it running all day is concerned, some dehumidifiers have a "Constant" or "Continual" setting. Which means it runs constantly. Either while dehumidifying or defrosting. In addition, most Danby dehumidifier models are designed to have the fan run even when the compressor is not running. This is in order to circulate the air in the room and make the unit work more efficiently. This is a standard feature and cannot be programmed to stop.
Hope this answered you questions.
Apr 24, 2011 | Danby DDR4009EE Dehumidifier
Why does the dehumidifier seems to run constant without collecting any water?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 25, 2010 | Fedders A7DH45B2A Dehumidifier
Hi, bought one two weeks ago. Try it on auto and set at 'normal', and 'dry' and the unit will stay running with out stopping over a period of day and a half. Collected about 1/3 tank of water. Phoned...
If you are in a very humid room or area it will not shut of until it reaches desired humidity% level that is set. If it is reaching the set level and not turning off I would return it.
Oct 06, 2009 | Whirlpool AD50USS Dehumidifier
Runs but does not remove water
If only the bottom part if your coil is geting cold or freezing, it's low on Freon.
Please rate solution
Sep 05, 2009 | Fedders R6DH45X Dehumidifier
Dehumidifiers Logo
80 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
