Will not make ice anymore
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
SOURCE: ice maker not working
This is extra Fridge moved to garage.don't know when ice maker quit. Side by side is staying frozen but ice maker not working. Water is hooked up and comes out of water dispenser outside of fridge.
SOURCE: ice maker quit producing ice, cubes were not solid before,either.
shelling:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
