Question about Pilot Precise V5 Stick Rolling Ball Pen, Extra Fine Point, Blue Barrel/Ink, 12-Count 35335
How to remove filter from the barrel of pilot v5 pen
FS2S0 universal stylus laser pen how do you put the batteries in
If you lay the combo pointer on the table with the stylus to the left and the laser end to the right...then pick it up and unscrew the laser end of the barrel from the stylus end of the barrel, or unscrew the clip portion of the pen from the stylus barrel end....the batteries will be in the clip end of the pen....remove and replace batteries with in kind and reassemble.
May 26, 2014 | Computers & Internet
I have a Pilot FriXion Erasable Gel Ink Pen. I want to know how to insert the refill. Please assist. Thank you.
Hi... Slightly above the rubber finger grip (about 1/8 of an inch) is where the pen unscrews. Once you have it unscrewed remove the old ink cartridge & place in the new one, there is no spring to deal with, so it just drops in.
Mar 30, 2011 | Pilot Pen Frixion Erasable Gel
My mp510 misses lines after cleaning and deep cleaning....HELP! Gail
This worked for me a few times so far - i saw a picture guide on e-how but I can't find it at the moment.
Open the printer cover
Take out the printer cartridges, keep them upside down and put some sticky tape or the original orange seals that come with the cartridges over the outlet holes, then turn them back.
Remove the printhead by lifting up the grey lever and taking out the black printhead (it's the black half-box with 4 slots in it and the ink-filters at the bottom). Soak the box in cleaning solution overnight to dissolve the dried ink. Shake it off until it's dry and reload it all. Now try it.
If it's still got lines, it's a bit more of a hassle. Repeat the steps above, but you'll need to find a pen barrel to fit over the filters - one for the black and one for the colours, or cut them to size. Rinse the print-head in water, then submerge the print head half-way in water, fit one pen-barrel over the black filter and suck water in (it's not easy) until the water is clear. Do the same for each of the others with the other pen. Dry the print head by shaking it (don't use tissue - you can use a hairdryer) and re-install the whole lot. It's worked twice for me now. Try not to let the ink run dry which will help.
Aug 04, 2010 | Canon PIXMA MP510 All-In-One InkJet...
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/IQAir-healthpro-plus-owners-manual.pdf
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
GoVacuum
Apr 08, 2010 | IQAir HealthPro Plus Air Purifier
My wacom pen does not work at all, the mouse on the tablet does though
on some older pens, the barrel can spin out of position. If your barrel turns, it can mess up it's function.
Turn the barrel until you hear or feel a clicking into position and try again.
If that doesn't work, move wacom cable to a different usb port. worse case, replace pen.
Mar 14, 2010 | Wacom Intuos3 Graphic Tablet
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
SAN Disk Pen drive detection
you connect your pen drive in your PC that will pop up one window named found new hardware....connect to internet and click on that window....that will ask tom install driver....follow the step and install the software.... restart your PC this problem will get over...\hope bthius will helps you... Thank you.....
Oct 10, 2009 | Express FormTool v5 (1077917SF)
How to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Jan 18, 2009 | Wacom (EP130EPE) Digital Pen
Pilot Precise V5 Stick Rolling Ball Pen, Extra Fine Point, Blue Barrel/Ink, 12-Count 35335 Logo
12 people viewed this question
Top Pilot Office Equipment & Supplies Experts
k24674
Are you a Pilot Office Equipment and Supply Expert? Answer questions, earn points and help others
