Question about JVC Audio Players & Recorders
Jvc rv b99 right speaker cuts off at high volume
When i increase volume to 20 up the subwoofer on the right side turns off and i have to restart jvc to get the sound back on but cant increase volume.
3 Suggested Answers
  • 29 Answers
SOURCE: jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
Posted on Aug 18, 2009
techman
  • 3130 Answers
SOURCE: model rv-b99 loses presets and does not power off
whenever I run into a memory issue with a portible unit that uses a battery backup I have found battery corrotion on the battery cointacts! also remove the main power source the batteries the wall plug and let it set for several minutes and hit the power switch a few times then retry everything again
Larry(techman)
Posted on May 14, 2010
I have an older JVC Shelf Unit with the main control unit in the middle and a left and right side speaker that contains a built in subwoofer on each side, lately the Speaker cuts in and out at higher...
It's one of three things things:
First, examine where the speaker wires are plugged into the receiver. Are any of the copper strands touching one another? If so, remove the excess stripped wire and reinsert it. Problem solved.
Test two: bad speaker. to test, swap the speakers (hook the right speaker to the left speaker jacks and the left speaker to the right speaker jacks). If the RIGHT side now cuts out, you have bad speakers.
If the speaker on the LEFT jacks still cuts out, your amplifier is going bad (which could cost between $50-$200 to repair).
Jul 01, 2011 | JVC Audio Players & Recorders
When I turn the knob to increase the volume, it goes up to three and drops back down to zero. It does this everytime I move the knob at a normal pace or faster. However, if I push the knob slightly in and...
It could be a safety protection meaning you could have a shorted speaker check all speakers and wiring, or it could be a defective volume control, try cleaning the volume with a contact cleaner spray you can find at any good electronic store (you normally have to open the radio to reach the POTENTIOMETER/VOLUME) to be able to spray inside it, than alternate (high/low) the control repetively to move/clean the volume's circuitry
Feb 09, 2011 | Car Audio & Video
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
Aug 06, 2010 | Logitech X-530 Computer Speakers
Model rv-b99 loses presets and does not power off
Larry(techman)
May 14, 2010 | JVC RV-B99GY Cassette Boombox
Jvc car radio
Speakers have a tendency to change characteristics. Take the radio out and carefully disconnect one by one speaker. Don't disconnect all of them if you don't know which wire goes where. Then try increasing volume to the cut off limit. You may be lucky to find the speaker that cause the trouble.Try a different speaker prior to unit repair attempt
Jan 21, 2010 | JVC AM FM CD DET FACE CAR STEREO
Sub seems to not get louder with volume increase. It seems to be overpowering at low volume or boomy then as you increase volume the front main speakers seem to take over.
Try adjusting the frequency cut off of the sub and also play with the gain control on the sub. Turn your system up to where your front speakers are sounding as you like. Then try adjusting the sub to match the fronts so you have a good balance and blend.
Aug 05, 2009 | Velodyne CHT-12 Subwoofer
Subwoofer switching off
have you checked all speaker conections? is the cooling fan working ?are you using the correct speakers supplied with the unit ? have you tried using headphone's if so could you then increase the volume .hope this helped.if you tried everything and are still having problem's i think the amps output transistor's or module is failing.you could try tapping the unit if you get a crackling sound you might have dry joints ..good luck farr64
Apr 29, 2009 | Televison & Video
Jvc rv-b99 cassette door jammed
Apr 02, 2009 | JVC RV-B99GY Cassette Boombox
JVC Surround Sound System
The problem on your sub is your speaker is faulty the end of the speaker coil is burnt so at a certain volume it`s makes a short .I hope that would solve your problem:)
Dec 29, 2007 | JVC SP-PW100 Subwoofer
37 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
