Cars & Trucks Logo
k
kyla Posted on Mar 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i have just installed a new stereo in my 2002 Holden Astra i blew a fuse and needed to replaced
When i went down to pick up a new fuse i forgot where the old one was. my stereo is working fine but now the dash display isnt working. does anyone know where i can find a fuse map to make sure i have all the bits in the right places?
2wsx
Level 2:
  • Expert 128 Answers
  • Posted on Mar 27, 2014
2wsx
Expert
Level 2:
Answers
128
Questions
Helped
32830
Points
258
There is tons of materials on youtube and on internet....
instead of Holden astra, type opel astra or vauxhal astra, it's same car in europe..... so google opel astra fuse box
5 Related Answers
Anonymous
  • 1118 Answers
  • Posted on Jan 21, 2009
SOURCE: Dash Instrument Panel Lights are dead - gauges work fine
do you have taillights? most of the time there on the same fuse. also chk. to see if plug is all the way in on your headlight switch.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Feb 16, 2009
SOURCE: Infinity radio - display window not functioning
inside the radio is a miniature bulb that back-lights the display, this is true of all radio's, in fact they all use the same tiny bulb, these do burn out from time to time, u will need to remove the radio/CD unit and then pull the top cover off, inside just behind the display u will find a small twist in socket that contains the bulb, u can buy this bulb at any full service auto part's store for about $2
Anonymous
  • Posted on Apr 24, 2009
SOURCE: 2002 Sebring LXi Convertible Starter Motor Fuse Blown 2x
Starter solenoid. I don't have the page here but in chiltons a page shows the ignition to fuse to relay to starter and if you look closely it's quite basic. I had same problem with constant fuse blow #8. The solenoid over time wears and sometimes sticks. When it sticks, your system can overload thus burn fuse. I bet you never stalled out while driving, but only when you shut off and start somewhere it's a no go. That's because you're system is already engaged. I had to change starter as solenoid part of it all. I see others suffer this same problem so please share this around. Solenoid can stick for a millisecond.
Anonymous
  • 5 Answers
  • Posted on Jun 02, 2009
SOURCE: Dash Lights went out, is it the fuse or the bulb? If its the fuse do you know which one it is?
look for 5 amp fuse
Anonymous
  • Posted on Jul 12, 2009
SOURCE: Fuse Diagram?
my pod clock stopped working as well and i replaced the fuse for the cigarette lighter and it resolved the issue give that a shot
Need to install mp5 stereo to holden astra 2005 ah, need wiring components, as adaptor has been cut
Go to Repco, they sell adapter kits for nearly every Australian car to fit nearly every stereo.
Need colour code for holden astra 2002 stereo
Do you need to paint the stereo? A local automotive paint supplier will be able to mix you some up without a paint code they use colour matching cards
2answers
Holden astra 2002 rough idol
If you replaced the timing belt and the car has been doing this, it is possible you are 1 tooth out with the timing belt.
How to replace 3rd brake light holden astra 2002
Hi there, the light should have clips or screws to hold the cover on, once off just pull the bulb out, it should be a wedge bulb, hope this helps
Need to remove centre dash on 2002 holden astra
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few
for now u can try reliable-store.... let me know if u need help
thanks
I need a diagram for the fuse box located near the battery of a holden barina xc 2001 as I need to find which fan relay that keeps coming up on the computer. I have one diagram of the one near the front of...
GMC xc barina fuse box location Questions & Answers - Fixya
www.fixya.com/tags/xc_barina_fuse_box_location/browse/gmc
Locked stereo in 1995 Holden Barina My battery went flat in my barina and now the ... Just changed the battery in a 2001 Holden Barina now there is no power just ... fuses should be in the box under the hood, there will be a diagram showing ... a 1984 gmc jimmy s15 fuse box located? the fuse box should be located near or ...
2002 Holden Barina Comments (r97719), Page 4
www.carsurvey.org > Holden > Barina > 2002 > Review
Apr 19, 2013 - 2002 Holden Barina from Australia and New Zealand - Comments ... The relay is in a box with a plastic cover on the left side (passenger) beside ... Hi, your Combo problem is the MAF sensor located near the air intake ... Hi I was hoping youfound the problem to your car, as my daughter's 2001 XC Barina is ...
[PDF]holden barina fuse box diagram - Donnie Slocum
www.donnieslocum.com/file/h/holden-barina-fuse-box-diagram.pdf
1helpful
Security system 2001 holden astra
hi, I have the same problem. The central remote locking is controlled by the soriginal stereo. Thats why it has an extra section of wires than other stereos. I cut this section off and connect it back to the original stereo and the remote lock works again. but as long as you connect the rest of the wires to the new stereo, the lock lost again. Now is like nly music or the lock. I have not find a way to let both of them work. Please let me know if you do.
Top Holden Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Holden Expert? Answer questions, earn points and help others
