Question about Rowenta Commercial Garment Steamer - White
Provide me services in pune
Its not working, pls get me service or service man who can repair it or get repair it.....
My rotary iron won't go round were can I get it fixed
Many sewing machine or vacuum cleaner repair shops also provide repair services for other products. If you find one in your area, I'm sure you can call ahead to make sure they can help you.
Jun 10, 2015 | Irons
I blew a circuit breaker a while back and my unit has not worked since. Is there a reset button or fuse I can replace?
I can not find it either! I talk to the company that shows first on the list when you go into google and they apologize as that sewing machine center does not sell them since 2009. I asked if they could trouble shoot it with me as when I turn it on has a non stop laud sound. They insisted that they could not help. I asked them to remove the item from the website if they do not sell it or can not provide service for it. They did not wanted it. THAT SEWING MACHINE company just want to use it to bring more customer to their website....THEY DO NOT CARE ABOUT ANY CUSTOMER SERVICE. Bad Business do not purchase from them as they can not stand and provide service for the products they sold you.
Aug 04, 2014 | Euro-Pro EP5100 Iron
Rowenta cord repair
I would get the part for your specific Rowenta iron from the Rowenta service center for this half of the US:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Then, if you do not want to send it there, go to local Applicance servicer you trust to have cord replaced locally if you prefer. I know it seems picky, but consumer products are UL approved, and I would not want loved ones working with a product I did not have serviced properly.
May 25, 2010 | Rowenta DG-980 Iron
Trigger button broke during ironing. What to do?????
The fix is easy, order the trigger that has an actuating tab that is probably broken off. Gently pry up the blue cushion from the front to the back near the cord and you will see the tab lying over the switch. I order my parts from the Rowenta Region Service Center below:
Keep us informed as you resolve and solve the problem. It is a fine machine and well worth the repair.
May 10, 2010 | Rowenta DG-980 Iron
I have stuff on the bottom of my iron that won't come off with iron cleaner. It seems like the iron plate should be sanded and buffed to get it off. I do not know what it is. I have not used my iron for...
It is man made polyester or nylon blends in fabrics you ironed that melted on the hot surface. DO NOT use sand paper or anything more abrasive than Bon Ami or other MILD cleanser...matter of fact I use a trusty orange stick or throw away wooden chopstick to gently buff the deposits off. You could try more agressive solvents and such, but I choose not too...just patience and plenty of rubbing with the wood.
Rowenta does provide a sole plate cleaner, but I have not used it. Go to the Rowenta USA website or use Google to find it if you choose to.
Mar 19, 2010 | Rowenta DG-980 Iron
Steam master Iron (Model 4215/003 ) is not heating with water in
May be the timer and heating element seems to be faulty, And i don't want you to check it.. without proper precautions since its electrical equipment..
Please contact service person near by It takes very less time to service it..
Hope this info helps
Jun 01, 2009 | Sunbeam 4214 Iron
Need the repair manual for a black and decker digital advantage iron. I will turn on but will not heat. rmsc
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the iron isn't heating, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
May 04, 2009 | Black & Decker D2030 Iron
I would like to send my Rowenta Steam Iron somewhere to have it repaired. The piece you click to activate the steam has ceased to work. Where could I send it? Thanks!
If I were in your shoes, this is exactly what I would do. Please go to this website which gives you the warranty approved service centers:
http://www.rowentausa.com/rowenta/frame.aspx
If it is not under warranty, it would be best to telephone the Ph. # of the service center closest to where you live. I am sure that they would be able, and glad; to "Fix Ya'" (Ha! Ha!) right up with an approved appliance repair business, near your home; especially for one of their Products. Best of LUCK & Have a Great Day!
Jan 14, 2009 | Rowenta DG-980 Iron
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Commercial Garment Steamer - White Logo
27 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
