Question about MSI 845GVM-V (MS-7057-010) Motherboard
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
Can i put this pc5300 on pc3200 slot at msi 845gvm-v board of mine?
i need it to upgrade my memory to 1 gb, even it may be upgrade to 2gb max. need your solution for this one... or may be there is another alternative? cause i heard that pc5300 is better than pc3200...
thank you all...
  • 476 Answers
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Posted on Jun 15, 2009
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I bought an Acer AO532h-2964 netbook, and I'm wondering: can I upgrade the RAM from 1 GB to 2 GB, and if so, which memory chip should I buy?
yes you can, your netbook can have a max of 2gb ram and a max module size of 2gb.
So you have 1gb pc 5300(ddr667) installed, and you can buy 1 more 1gb module, laptops use sodim.
Aria.com has a 1gb stick for £25
http://www.aria.co.uk/Products/Components/Memory+-+Laptop/DDR2+667MHz+PC5300/
you could also try play.com / amazon / ebay
Jul 10, 2010 | Acer Computers & Internet
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
I want to upgrade my memory. my current memory is 2x256mb pc2 3200. what is the max limit of memory can i have? is it per slot or total? if i get pc2-5300 is it backward compatible to pc2-3200? anyone with...
You can have a maximum of 2GB in that laptop 1x1GB in each slot, the ram speed is PC3200, PC5300 is too fast so the bios will not recognize it as the maximum is only 400MHz, stick to the PC3200 for each stick.
Ask for SODIMM DD2 SDRAM, PC3200 2x1GB, i also recommend Kingston as the ram manufacturer.
Regards.
Aug 01, 2009 | Dell Inspiron 6000 Notebook
Want to add memory to Gateway 700x
Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
Visit this link : http://www.simpletech.com/upgrades/gateway/700x/700xddrintelp428ghz/
.................sodeep
Mar 31, 2009 | Gateway 700 X PC Desktop
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
Memory upgrade for Windows Vista
Yes this motherboard supports up to 2GB of RAM so you can use 2 stick of 1 GB to those slot ...
Jan 16, 2009 | Asrock P4VM8 Motherboard
Total memory
with out the model number of your computer. i would guess that by you having 4 slots you would need 4 (512mb) memory sticks that would give you a total of 2gb of ram. which is probably your max. also pretty sure you have to have the same size in each slot. you cant mix 1gb then 512mb it will not work.
Dec 22, 2008 | Computers & Internet
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
MSI 845GVM-V (MS-7057-010) Motherboard Logo
686 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
