Question about Whirlpool AWG320 Front Load Washer / Dryer
How clean dispenser tray for whirlpool awg3200/1
How to remove and clean the dispenser tray
Maytag 5000 series washer leaking.Removed front access panel ,saw water is trickling from dispenser tray area. Pulled dispenser drawer,cleaned/inspected with nothing really standing out as a problem.
Verify that that the hoses from the dispenser tray to the tub are not clogged. Detergents and fabric softeners can build up inside the hoses and cause partial or complete clogs that will cause the dispenser trays to overflow and thus leak. This is a common problem.
Oct 04, 2015 | GE Washing Machines
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
My dispensing tray always has water in the conditioner section which I have to empty every time I use the machine
Remove the dispensing tray and thoroughly clean it. Use a bottle brush. You may already have done this. If that fails the network above dispensing tray may be fouled. This should then be cleaned. As it is fairly inaccessible, being above the dispensing tray, I can only suggest using a toothbrush to clean the upper surface (which faces down)
[some conditioner dispensers work by a siphoning method which requires a 'tube' - in fact an open channel - from above]
I have the same problem in my washing machine but haven't got any further that reading up on the internet, and thinking about it. I plan to use an old electric toothbrush in my attempt - so I don't know if it will work !
15.January.2015
Jan 15, 2015 | Beko Washing Machines
How do I empty water from conditioner dispenser
The dispenser often has a small amount of water in it after a completed cycle so that's nothing to worry about. A lot of water usually means the dispenser needs a good clean. Pull the dispenser as far as it will go and then give a sharp tug to pull it completely out. The middle dispenser cover can then be taken out and cleaned, and so can all the other parts you've removed. The pipes in the machine and in the dispenser tray should be cleaned out well, as these usually cause the problem of retaining water. Put the cover back on the centre section securely and then push the whole tray back into the machine gently. Good luck!
Oct 15, 2014 | AEG Lavamat 72640 Front Load Washer
I have a whirlpool 4.4 duet steam washer. When I wash a load and the cycle is complete, there is water in the liquid dispenser area.
Hello, If you are meaning that there is water in the softener cup in the dispenser, some water is normal. If it is full to the top, then removed the dispenser tray and clean the underside of the dispenser.
Apr 21, 2014 | Washing Machines
How do you clean the ice and water dispenser on the freezer door of a whirlpool model num ed0gtqxkq00
Remove the drip tray then pull the bottom of the dispenser cover down and out, it should pop right off.
Mar 14, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Clean detergent tray
The tray can be removed by pulling the tray out until it stops by itself, then push down the release latch inside of the dispenser and then you can pull it out the rest of the way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 19, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
51 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
