Question about Mtd 22" Yard Machine Push Mower
No spark will turn over doesn't seem to be any spark
  • 1,162 Answers
First remove plug hold it against the engine have someone to pull cord while holding plug an watch for spark. If it does you have a fuel problem. Its a good idea to replace the plug anyway. They are a common problem rhat goes bad easily. If you have spark empty fuel tank remove carb. Purchase a rebuild kit, very cheap, an replace rhe diaphram an other parts in kit. Be sure to clean out all the orifices with a small brass or steel bristle from a brush. Careful not to enlarge the ports. Use carb cleaner to clean all parts. Carb parts go bad after a couple of years. This is an easy project. Put carb back on an it should run if you put it all back together correctly. Making sure cables an spring are in exact places. Hope this helps
Posted on Mar 27, 2014
Pontiac grand am gt 2000. Turns over, no rpms or doesn't seem to be sparking?
if 4 cylinder 1342 is the firing order if 6 cylinder just look at the manual or look at the top of the cylinder head
May 04, 2013 | Cars & Trucks
My HUSQVARNA HU775H will not start. I just replaced the spark plug and still nothing.
are you saying it wont even allow you to pull starter out ? if this is so , then remove the spark plug completely and try if it still wont pull then seems it was overheated and now piston is fused to cylinder wall , if it does allow u to pull it , ck your reed valves in head seems there not releasing when they should also have a look at rope in starter it could be all twisted up keeping you from pulling it out as well
Mar 08, 2013 | Husqvarna Garden
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
Mtd yard tractor will turn over will not start
if it doesn't fire with starting fluid then there is a problem with spark unplug the connector at the engine and try starting fluid again if it fires with the small connector unplugged the it could be a safety switch if no then pull the cover off the top of the engine and check the coil
May 20, 2012 | Garden
The car wont start.
Hello! A few necessary items to successful troubleshooting; What engine is in the vehicle and, since it's a 1996, it has OBDII diagnostics and a Check Engine Light...Is the light on?...If so do you have access to a scanner to find out what trouble code or codes are stored?...Lastly, have you checked for spark? Because your saying it doesn't "seem" to be getting spark...Hate to hit you with a lot of questions but without these particular pieces of information it would be difficult to narrow down...Please add any thing else that seems important...Awaiting your reply...Guru...Saailer
Dec 08, 2011 | 1996 Chevrolet Camaro
The engine turns over but the motor will not start. The van was running fine when it was cut off. It doesn't seem to be getting gas.
It's very likely your fuel pump has failed. Have somebody thump on the fuel tank while you're cranking the engine and see if it starts. If it does, replace the fuel pump. Otherwise get your fuel pressure checked, and check for spark. If no spark, check to make sure the distributor is turning(if applicable) If a 3.3 motor with no spark, suspect the crank sensor or cam sensor. Crank sensor is much easier to replace if experimenting.
Sep 05, 2011 | 1990 Dodge Caravan
1997 sunfire won`t start
are you getting continuous spark? bad electronic module? check spark first. should be continuous. do you have oil pressure...some vehicles won't run if oil pressure is not there.
Jul 12, 2009 | 1997 Pontiac Sunfire
Mtd 22" Yard Machine Push Mower Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
