Question about Kitchen Appliances - Others
Oven CMP202 Rational combimaster not working E-17 displayedlay
E-17 displayed even new board replaced
3 Suggested Answers
SOURCE: Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Posted on Jun 10, 2009
  • 45343 Answers
SOURCE: Brand new Rational oven SCC WE 61 displaying service 34-1-. What does this mean.
call the authorized service agent to get the reason for the code
it is under warranty so let them fix it
Posted on May 25, 2017
Rational combi oven
Any wires out the back that are loose?
Jul 04, 2013 | Kitchen Appliances - Others
Brand new electrolux range oven wont work, all that shows on display is F15
F15 means : signal lost between oven relay board & EOC(main computer board)
1. Test the harness and connections from EOC connector P16 to oven relay board J2.
2. Replace the oven relay board.
3. Replace the EOC.1. Test the harness and connections from EOC connector P16 to oven relay board J2.
3. Replace the EOC.
Hope this help. good luck to you.
Feb 07, 2011 | Vacuums
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
The Oven LED display does not work even though all the functions of the oven work.
You simply need a new LED board and these parts are very easy to replace.
Oct 19, 2009 | Jenn-Air JMW9530C Electric Double Oven
Jenn Aire Model SVE47600W
Thank you so much for this information. I can verify that this procedure worked (at least for me). I ordered the part from Digi-Key Corp (it was up to a whooping $.28), replaced the old capacitor, plugged everything back in and bam! A working display. There was a beeping and error message but after hitting the Cancel button on the stove, everything was working.
Note that this fixed the dimmed display only. All the other controls were still working--only the display was off. If you have other issues, this might not be a complete solution.
You need basic soldering skills, a small solder iron, a solder ******, and some rosin-core solder. The capacitor is labeled on the circuit board.
When taking the unit off the control panel the largest ribbon cable was clear plastic with embedded contacts. I'd never seen one of these before. The cable's contacts slide in behind the pins on the connector and are held against it by an insert in the connector. When I removed the insert, the clear plastic cable came completely out from the connector. I had thought I'd broken it. But just slide it back in behind the pins, aligning the cable contacts with the pins and put in the connector insert to hold them in place.
The Digi-Key part number for the capacitor is P10292-ND. I ordered 5, just to have a few spares. The 5 caps plus first class postage came to a total of $3.51. Quite a difference from the $160 for the whole unit!
Thanks again to ultigerfan for making this information available.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Clock display board
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Apr 11, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
