Question about Toshiba Televison & Video
My Sony KP-FX532M91 TV blinks and shuts down after like 8-10 blinks, my technician asked me to buy MCZ3001 and Flyback, the shopkeeper is asking for Flyback type and model. What type and model fits in Sony KP-FX532M91 TV?
  • faisal Ijaz
    faisal Ijaz Apr 03, 2014
    hey mark, the TV is fixed now, Sony guys just replaced two MCZ3001 ICs and it got fixed. It costed me approx $34 X 2 for ICs that is 68 dollars, paid 20 dollars for service fee (quoting in dollars though i paid in Pak rupess:))
SOURCE: Sony KP-51HW40
Unfortunalty I'm not sure how to resolve you current problem. It appears I'm following in your foot steps with the convergence issue (image appears in 3d). I would really appreciate knowing how you resolved this issue (including cost) and if the two issues are related. good luck
Posted on Apr 29, 2007
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
  • 51 Answers
SOURCE: sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Posted on Dec 15, 2009
Testimonial: "very quick response "
  • 125 Answers
SOURCE: I have a 51 in. Sony model kp-51ws520. when I turn
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Posted on Mar 24, 2010
jdvillanueva
  • 2098 Answers
SOURCE: kp-fx532m91 green blinking and followed by red blinks
10 blinks is a high voltage protection. This is why it has a retrace lines on the picture. It can't be fixed by reset or unplugging the set from the outlet because there's a faulty parts inside. It needs to troubleshoot the deflection circuitry to determine which part(s) gone bad. You need to ask for an assistance of a qualified TV Technician because this kind of symptoms is not DIY unless you have an experienced in electronics.
Also, check if you're unit is under warranty period/extended warranty, avail it because the manufacturer will fix it for free. Opening the rear cover will void the warranty.
Posted on Nov 12, 2011
Kp-fx532m91 green blinking and followed by red blinks
Nov 12, 2011 | Sony KP-FX532M91 TV
Sony tv model kp-fx432m91 LED light blinks
I can assist you with that problem the LED blinking is actually indicating a specific error based on the number of blinks.Let me know how many blinks in between pauses.
May 05, 2011 | Sony KP-FX532M91 TV
MY SONY PROJECTION TV WEGA KP-FX432 BLINKS 10 TIMES THEN TURN OFF.PLEASE HELP ME
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-FX532M91 TV
Sony Wega Television - Sound and no picture
If this is a LCD projection then its time for a new lamp. Have your lamp placed.
Please leave comment:
thanks
Oct 06, 2009 | Sony KP-FX532M91 TV
Sony porogction
try the sony website...
Sep 13, 2009 | Sony KP-FX532M91 TV
Led 10 blinks then turns off
According to sony,
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Thanks.
Jun 16, 2009 | Sony KP-FX532M91 TV
My Sony WEGA KP-FX432M91 TV LED blinking few times and then turned off please help me to solve this problem Regards Nima
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Sony KP-FX532M91 TV
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
