Question about Suzuki SP-A3 A/C Adapter for SP-37
Suzuki sp 37 keyboard i just bought this today and it turns on it looks like all the buttons light up and work there is just NO SOUND what should i do to fix this the spearkers do give an indacation t
AS I HAVE BEEN TRYING TO FIND THE ANSWER ABOUT MY SUZUKI SP 37 THERE IS NO SOUND COMING OUT OF ONY WHEN U TURN IT ON AND OFF YOU CAN HEAR THERE CONNECTED WHAT CAN I DO TO FIX THIS CAN I TROUBLE SHOOT
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 | Casio Music
Why do keys produce no sound?
Hi Kyle:
Have a look at your manual.
Sometimes you'll find that there will be an "input" setting required.
You might also try google with his link.
https://www.google.ca/#q=Williams+Allegro+88-Key+Digital+Piano
Hope this helps.
Cheers.
Oct 13, 2015 | Williams Allegro 88-Key Digital Piano
Yamaha dgx-640 display
There is a small turning button on the back of the keyboard to change the screen tone and brightness,happend to me and this fixed it,i thought mine was broken too,till i spotted it
Oct 21, 2012 | Yamaha DGX 640 Keyboard Arranger
Korg sp-250 randomly changes the voicing
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
Apr 08, 2012 | Korg SP-250
Hi As recently as a month ago I bought a Kurzweil PC3K8 from sound solutions. On 13/08/2011 I took the keyboard (in a flight case) to a gig. After setting up the keyboard and powering on, the blue light...
Hopefully you didn't take it on a flight as sometimes they use bomb detecting equipment that subjects cargo to either high levels of radiation or high electro-magnetic fields. This can damage the equipment. It sounds like the processor is not running. There usually is a screen contrast control that can be turned enough that the screen appears blank, but usually you can get a sound out of the unit without reading the screen, Look in your user manual for a FACTORY reset or restore and pperform that procedure. If that doesn't work, then repair is in order. If unit has been vibraated during transportation, it is possible a cable has come off inside. Since you just bought this, EXERCISE you warranty immediately.
Aug 14, 2011 | Kurzweil PC3K8 88 Note Performance...
KORG SP-250. Keyboard powers up, you can change all selections, five or six random notes sound, but the other keys produce no sound at all.
There is probably a cable loose that connects the keyboard itself to the processor... OR the key contacts have been contaminated by spilled liquid. The keys are scanned as a matrix. The contacts will be a conductive rubber pressed against circuit board traces. Clean contact "pills" and the circuit traces with ONLY 99% isoprophyl alcohol.
This is NOT for the unskilled to attempt a DIY other than carefully opening and looking for a cable that has come loose.
Mar 22, 2011 | Korg SP-250
I just got an sp-3 sustain pedal for my casio ctk 560l keyboard but have no sound when i plug it in. How can i get it to work? I there a button i have to press or something?
Make sure you are plugging it into the place for the sustain pedal. If you happen to plug it into the audio out it may kill the sound.
Sep 29, 2010 | Casio SP3 Sustain Pedal
Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Jul 20, 2010 | Casio Music
M-audio ProKeys 88sx -- all led lights flash, no sound Upon turning the keyboard on, all led lights on the top panel flash. No sound from the keyboard. Is there a re-set button or something?
I have two of these. First thing check your power adapter for output. Just because LED's are on doesn't mean there is correct voltage... There is no reset button... Cycling power serves to reset it.
ALSO check the power input connector... sometimes those get intermittent and break connection due to vibration and initial current surge when turning on.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
Suzuki SP-A3 A/C Adapter for SP-37 Logo
62 people viewed this question
Top Suzuki Music Experts
Michial Gueffroy
amine razkaoui
rhodesworks
Are you a Suzuki Music Expert? Answer questions, earn points and help others
