Connect headphones lg tv no sound
Plug headphones in no sound. Only from tv
SOURCE: I am trying to connect
Have you got the TV set to the correct channel ? A lot of the TV's have a PC input, but no sound when that input is selected, so plugging the audio into another input won't allow you to use it as a monitor and have sound at the same time. If it were a desktop PC, you could use a DVI-HDMI convertor and get the sound in that way, but most, if not all, laptops have analogue 15 pin video outputs.
Posted on Jul 21, 2008
joboo1
  • 257 Answers
SOURCE: can't connect wireless stereo to sylvania 6620LF4
Hi, Ok, I now understand what the problem is. Sorry I missed the fact that it is due to no audio outputs on the TV. The audio board is designed to power low impedance speakers and doesn't have a big power amp to drive them. I do not have a schematic of that particular TV so I do not know how the headphone jack is wired. The way it basically works is, when you insert the plug, the tip pushes a contact away from another contact thus making one circuit and breaking another. You can test this externally by inserting an unwired plug or look at it from the inside and bridge the tip connection. I would only advise this if you have some technical skills. Other than that the thing is working like it was designed, they don't want you to use both. Sorry, I hate to give this type of news, but I am one of the only ones who will. Good Luck to you!
Posted on Feb 20, 2009
  • 20 Answers
SOURCE: No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Posted on Apr 07, 2009
  • 32 Answers
SOURCE: no audio out on hdmi with desktop
Chances are your desktop doesn't support audio through HDMI. Try to find a spec sheet for the unit you have, an upgrade may be possible
Posted on May 27, 2010
  • 4234 Answers
SOURCE: How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Posted on Jul 11, 2010
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
Why did my LG 42 inch tv flat screen tv sound go out when we plugged in headphones?
HI,
Its normal. I all the device when you plug in the headphone the internal speaker will turns off . Use your logic we use headphone for privacy.
www.electro-medical.blogspot.com
Sep 05, 2015 | LG Televison & Video
How do I connect jbl headphones to a lg tv, model 47LM7600-up?
Unless there is a jack for plugging in a set of headphones to the TV, it may not be possible. The manual would clearly show if the TV has this option. Or there may be a way of using a wireless set of headphones, but then your TV would have to have the capability of transmitting the sound to the headphones.
Sep 18, 2014 | Televison & Video
How do I get sound from headphones and LG t.v at the same time?
OK, play music and try to plug and unplug several times.
if sound heard form phone just leave.
otherwise get replaced the headphone socket.
Sep 15, 2014 | Cell Phones
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
Lg lcd tv 37lc2d no headphones socket - how do i connect headphones?
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Mar 17, 2010 | LG 37LC2D Television
How to hook up bose headphones to tv
The best way to get sound to connect to the headphones would be if you had an audio system connected to your tv, like an audio reciever. Then you could just plug the headphones into that and voila, you have sound. Also recievers give better audio quality. The other thing I would suggest is getting wireless headphones and connect them to the tv itself. But then they wouldn't be your Bose phones. Hope this helps. Cheers.
Oct 02, 2009 | LG 32LG30 32 in. LCD HDTV
78 people viewed this question
 Grubhead
Grubhead
