Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Here are some things that you can do to try to correct it without disassembly. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Do you get an E18 error? If so, then the lens motor is bad, or you have contamination in the gears (sand, dirt, etc), or mechanical failure from dropping the camera. This will require repair by Canon or other camera repair services.
This is caused by a bad lens motor, contamination in the transmission, or mechanical damage from dropping. The only fix for this is to have it serviced by Canon or other camera repair facility.
An E18 lens error or a "lens error restart camera" message is almost always a problem that must be sent in to the service center for repair. Though most often the result of a fall or other physical impact, they can occur spontaneously. Like a car stripping its gears, the lens motordrive mechanism has gotten off track. Often the camera will make a grinding noise as the camera lens attempts to track back and forth and occassionally the unit will beep several times and turn itself off.
Unfortunately most point and shoot cameras have very delicate lens mechanisms and it doesn't take much force at all to cause this to happen. Very often you may inadvertantly obstruct your camera's lens with your hand when holding the camera and turning it on. In these cases it is often possible for your lens to correct itself by actually turning the camera on and off several times (restarting camera). In the case of falls or drops, however, the impact damage is often uncorrectable by simply restarting and the unit must be sent in for service at that time.
If this happens to your camera through no fault of your own and you are still within your twelve month warranty period, simply send the camera in for service and the unit will be repaired at no charge. If you are outside of your warranty period OR it is determined by a technician that impact, liquid, or grit (sand or dirt) damage is at fault then you will be assessed a repair charge (even if within your warranty period).
Typically customers with out-or-warranty repairs will have a choice of either repairing their camera at the stated charge or (depending on the camera model) taking advantage of the Canon Loyalty Program in which they may opt to select a specific refurbished camera model of slightly higher model design - at a discounted price.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
my canon S21S dropped from coffee table onto carpet [thanks puppy dog]
now lens will not extend.
