Question about Wharfedale PowerCube PC-10 Subwoofer
Wharfedale PowerCube PC-10 Subwoofer still shows the red light at the back but doesn't work!
My wharfedale power cube 10+ was working off and on over a number of months but now it has stopped working all together, but the red light behind the SW is still on, I took it apart noticed all three fuses 2 internal 1 external are all ok, also checked the driver and it seems to working also, so it seems it will have to be the amp!? how much would you think a replacement would be?
3 Suggested Answers
gopakumarg43
  • 75571 Answers
SOURCE: I have recently purchased a
Hello
You just test your subwoofer first. For that disconnect the subwoofers' RCA cable from AV receiver then power on subwoofer, adjust the volume of the subwoofer to 20% of its total volume, if there is an auto power On\ off switch behind the subwoofer, make it off, and touch the main core of the RCA cable with your finger and listen whether there is a HUM sound or not. If there is no HUM sound, that indicates your subwoofer has some fault inside it.
If there is HUM sound, it is working, and proceed.
Press menu button on your AVRs remote control. Surf for speaker setup. Then to speaker confuguration. Note the status of the subwoofer. If it is Off, make it On.
If you need any more assistance, feel free to contact me through Fixya.
Ok
Posted on Dec 02, 2010
SOURCE: Wharfedale Powercube uncontrollable loud noise
Change the 2 elco's in the supply
6800µF 63Volt
Posted on Mar 02, 2010
Where do i connect the single rca plug from my pioneer home theatre sytem
usually it will go into the white plug on the back. if one of the rcas is labeled signal or LFE this is the one to put it into. let me know if you need further assistance.
Jun 14, 2010 | Wharfedale PowerCube PC-12 Subwoofer
6800µF 63Volt
Aug 01, 2009 | Wharfedale PowerCube PC-12 Subwoofer
Wharfedale 10inch cude subwoofer that has a feedback hum when con
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Jul 14, 2009 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale PowerCube PC-12 Subwoofer Problem
ok , what your going to need to do is give me the numbers on the amp IC's , and i will see if they are available , but first you will need to see if the pre amp transistor is failing , to do this leave the power off and unplug from the wall then with a digital multi meter on diode check , check to see if the emitter to base reads about 680- 700 , if it does then its ok but i would replace that anyway because it could be the reason the amp is not amplifying correctly , sometimes they don't act up untill power is applied , then also replace any resistors in line with the input line that do not read thier values( if you need help identifing them let me know and i upoad the codes for them) and also the electrolitic capacitors on the transistor line to the amp
once you have completed these steps let me know if there is a change
you can cross reference you transistor here also maybe the power amp http://www.nteinc.com/
Oct 29, 2008 | Wharfedale PowerCube PC-10 Subwoofer
Wharfdale PC 10 subwoofer
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Aug 20, 2008 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale dab radio da-110e
According to the manual the indicator lights go out when the batteries are charged.
Mar 16, 2008 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale Subwoofer problem
Take it to the shop from where you purchased it or try to web to get further information on their service outlets in your part of thw world. The problem is not a formidable one. It seems the IC in the Subwoofer and would not take more than half an hour to solve the problem. If it is under warranty get it replaced as well as the cables. Do not try to repair this yourself unless you know something about speakers and sound systems.
Sep 03, 2007 | Wharfedale PowerCube PC-10 Subwoofer
Subwoofer
do the fuses blow no matter what volume you are sending?
May 25, 2007 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale PowerCube PC-10 Subwoofer Logo
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
