Question about Electrical Supplies
How do i drain the gas out of the gastank on a honda 4000 generator
    Sergeant:
  • 415 Answers
On my generator, I just take the fuel hose loose where it goes into the carbureator and drain it from there.
Posted on Apr 03, 2014
3 Suggested Answers
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
  • 13 Answers
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
Posted on Oct 05, 2010
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
Aug 18, 2017 | NEC Mitsubishi MGE 4000 Generator ROU...
Honda generators how do i drain the gas out of the t ank
You can put a can under the carburetor bowl and remove the bowl drain bolt and loosen the gas tank cap.
Mar 27, 2014 | Electrical Supplies
Onan 4000 generator
Check the rotor slip rings and brushes first, the rings should be clean and bright
Jun 24, 2013 | Watts Onan Portable Generator - 4000 ,...
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
Generator does not start
The float bowl their is a drain bolt, take it out check for gas.
Aug 23, 2012 | Dewalt Generator. 6000 Watt Portable...
Child put at lest one cup 4-stroke oil directly into gastank of 2001 Honda *** 49 cc scooter. Origianally started and emitted greyish exhaust; now does not start. Battery charged. Gas tank full. Advised...
You might get lucky with new spark plug(s) and I assume you mean 2-stroke oil. Otherwise, drain tank and replace any fuel filter in system, then re-try with fresh gas and new plug (s)
Aug 01, 2011 | Honda Dio Motorcycles
Mar 22, 2010 | Electrical Supplies
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Sep 27, 2008 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
