Question about NComputing Computers & Internet
Install scanner pc
How to install scanner pc
    Sergeant:
  • 233 Answers
Most installations like this require you to run the install software first.
Then connect the device once the software gives the ok to attach.
Most devices today are USB and these can be plugged in hot.
IDE, Parallel, serial, PS2 etc are not. Meaning don't plug this in when the PC is powered up. Be ready to swap USB ports should the software not detect the device. This is rare but can happen.
USB 2.0 is a standard now with USB 3.0 on many newer machines.
If the Device can utilize USB 3.0 and your pc has this. Use it!
It is very fast and you can recognize a USB 3.0 part by the color.
It will be Blue inside. I have also installed scanners and other devices by connecting the USB cord, power up and then running the software.
Does not seem to matter to most devices now. But it is best to follow the instructions that came with the device.
Good luck and hope this helps!
Posted on Mar 29, 2014
Hi, I want to install both fujitsu fi 5750c and 5530C2 Scanners in same PC. OS is win XP. I tried through setup, but when one is installed, second one's setup says already having Scanner Utility...
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 27, 2011 | Fujitsu fi-5750C Flatbed Scanner
My PC is not pickup Acer 640P scanner as new hardware
1. uninstall the driver if u have already attempted
2. Disconnect the USB cable from the PC USB Port (the one that is attached to the scanner on the other end)
3. Install the driver for the scanner
4. make sure the power for the scanner is on
4b. When prompted attach the USB cable (the one that is attached to the scanner on the other end) to the PC
5. If it does not find ur scanner then
Do the following:
1. Change the USB cable and try again
If this does not work, get back to me again...
Mar 15, 2010 | AcerScan 620P Flatbed Scanner
Can't use my n650u scanner because the installation disk asks me to install the "Twain Driver" first. How do I do that?
You can try the following method:
Do not connect the scanner to the PC yet, first install the driver from CD, restart your PC. Then connect your scanner. Windows will hopefully recognize the scanner
Nov 24, 2008 | Computers & Internet
Scanner installed but getting message can not communicate with pc
Have you loaded the scanner driver software on your PC? Is the printer connected to the PC using a known good cable plugged into the proper receptacles? Is the scanner plugged into a known good power source? Is the scanner turned on? If you use one of the USB ports, your PC should automatically display NEW HARDWARE FOUND on your screen, and willl then ask if you want to install it using the SCANNER AND CAMERA INSTALLATION WIZARD.. You can also left click mouse on WINDOWS START, left click on CONTROL PANEL, and left click on the SCANNERS AND CAMERAS ICON. A new window should appear. Follow the instructions on this SCANNERS AND CAMERAS window, and you should be able to get your scanner working.
Aug 04, 2008 | Office Equipment & Supplies
Install my scanner with winXP
how to install my scanner acer Prisa 340p with winXP because the installation CD support only win95, win98, winNT,and when I connect the scanner to the computer ,the computer can see the new hardware but the installation failled, and the scanner doesn't work with the pc, what can...
Dec 02, 2007 | AcerScan Prisa 340P Flatbed Scanner
Scanner
Usually this is a problem with old (parrallel port ) H.P Scanners. Shut down your PC, remoce power of the scanner, remove the data cable of the scanner both at PC as well as at scanner end. Reboot the PC. reconnect the data cable and then the power cable ofthe scanner. Try using it. If you have win98, it should work now. If Win XP_P, reboot your PC, it should work. If the problem persists, try re-installing the drivers.
Oct 07, 2007 | Office Equipment & Supplies
Computers & Internet Logo
50 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
